1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 10 New Guy | | New Guy Joined: Oct 2007 Posts: 10 | Hey I have a stupid question... I'm trying to remove the brake & clutch pedals on my 52 GMC but I'm not sure how to take off the retaining clip without damaging it. Do you just hit it with a hammer and punch?
Thanks, Mike | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Not sure about yer '52 but my 38 is removed below the floor. The pedal and shaft are all one piece.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | In your 52 the petals are two piece, first from the rubber plate at the top to below the floor. Are you talking about removing it at that point or the second section from there to where both petals mount to the frame?
~Jim
| | | | | Joined: Oct 2007 Posts: 10 New Guy | | New Guy Joined: Oct 2007 Posts: 10 | I guess I should have explained better, I can get the rubber pedal and arm off, it's where the clutch and brake pedal arms pivot, they're both on a shaft then there's a spring and a funny-looking retaining clip that the assembly manual calls a "pin lock". It looks like maybe I could pry it off of the shaft, or knock it off with a hammer and punch, but I don't want to get it bent so that it won't hold right when I put it back on. I was hoping someone had been here before and had a good idea. Thanks for your replies.
Mike | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know why you want to take that apart but I would suggest taking the assembly off and working on it on the bench. Why do you want them off? | | | | | Joined: Oct 2007 Posts: 10 New Guy | | New Guy Joined: Oct 2007 Posts: 10 | I'm putting in a V8/automatic, I don't need the clutch any more but I want to keep the original brake pedal, so I just want to take the clutch pedal off the shaft, cut the arms off it and put it back on, just as a spacer for the brake pedal. It's just the one little clip holds everything on the shaft, should be real simple, I just want to be sure I don't screw it up. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | hey mikesoldpicup: The "assembly" is held on with what is called a Warped Washer. You need to bend half of it down and then it will slip out of the groove and come off. Then the washer,spring ect will come off the shaft. I'm doing the same thing you are but instead of cutting the clutch pedal off I had a friend of mine make me a "spacer" to slide on instead of the clutch. Hope this helps. | | | | | Joined: Oct 2007 Posts: 10 New Guy | | New Guy Joined: Oct 2007 Posts: 10 | Thanks Achipmunk! Then when I put it back on I guess just a couple taps with a hammer to make sure it holds good enough. That makes sense I'm just a little over-cautious when it comes to stuff like brakes, and that doesn't look like a part that would be easy to replace.
Mike | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | spacer sounds like a good idea! being cautious is a good plan also since parts like those get sent to the scrapper when somebody does a frame swap. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
