4 members (Rexville48, 1955 1 Series, fonz8261, Mike Roache), 65 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#386773 03/11/2008 9:26 PM
Ol' Marianne, the little 53' 5 window has decided to start going through batteries left and right. I'm getting 13 volts at idle and 13.8-9 at speed. A tad short but still in the green. Is it worth getting a new alternator?
Also the turn signal indicator (red 4 way) has started staying on of late and will run the battery low if I don't drive it for a week or so. Battery is brand new, 3rd one in 20 months.
Gott any ideas and how can I fix that flasher unit?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I am guessing you have had it (alt) tested at FLAPS? They should be able to tell you in seconds if your alternator is bad. As for the switch, Denny will probably chime in soon.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #386837 03/11/2008 11:26 PM
Riding in the Passing Lane
Try disconnecting the alt & see if the light goes out. Turn the lights on as you rev the engine & check the voltage. 13.8 is normal but it should retain it when there is a load on the system. I suspect you have a shorted diode causeing the drain on the bat. & possibly lighting the 4 way indicator.
1972 Chevy c10 Cheyenne Super
Open diode would be my guess as well. Do you know if your running a 10DN externally regulated Delco alternator or possible an internally regulated 10SI Delco? Your best bet would be eliminate the alternator and take it and have it checked. If your running a Delco just one of the 6 diodes bad will let it drain back and run the battery down.
Ken
