0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Ol' Marianne, the little 53' 5 window has decided to start going through batteries left and right. I'm getting 13 volts at idle and 13.8-9 at speed. A tad short but still in the green. Is it worth getting a new alternator?
Also the turn signal indicator (red 4 way) has started staying on of late and will run the battery low if I don't drive it for a week or so. Battery is brand new, 3rd one in 20 months. Gott any ideas and how can I fix that flasher unit? | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I am guessing you have had it (alt) tested at FLAPS? They should be able to tell you in seconds if your alternator is bad. As for the switch, Denny will probably chime in soon. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Try disconnecting the alt & see if the light goes out. Turn the lights on as you rev the engine & check the voltage. 13.8 is normal but it should retain it when there is a load on the system. I suspect you have a shorted diode causeing the drain on the bat. & possibly lighting the 4 way indicator. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | Open diode would be my guess as well. Do you know if your running a 10DN externally regulated Delco alternator or possible an internally regulated 10SI Delco? Your best bet would be eliminate the alternator and take it and have it checked. If your running a Delco just one of the 6 diodes bad will let it drain back and run the battery down. Ken | | |
