7 members (MRMEROTH11, TUTS 59, Barney1951, Gray_Ghost, Wickedbass, JW51, walter74),
96
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Who has good prices on tires for old trucks?
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Any tire dealer should be able to get the size you want. Most are competitive in price. An on line source would be Wallace Wade.
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Universal Tire has a nice online catalog with sizes widths. I don't know how their prices are compared to others but they have a large variety and attend a lot of the larger shows and if you preorder they will bring to show. Hope this helps. Dan | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Thanks Tiny and Chev4T6. I suppose maybe what I'm fishing around for is what are most people willing to shell out for tires these days? I know there are alot of places on line that cater to the vintage car and truck lover and it seems as though they are a bit on the higher end price wise plus shipping all that weight adds on to the final costs. Is there an equivalent for...lets say, a 6.50 X 16 inch tire that is mass produced today that is not defined as vintage that I can just go down to my local tire store and purchase? Or are you going to be stuck paying a "higher" price because of the vintage nature in order to get it to fit on your truck? What are you folks willing AND not willing to pay for a new tire on your Stovebolt? $100 bucks a tire? More? Less? Whats reasonable in your mind? Were talking "new" here...not used or freebies.
One more thing. Tube or tubeless?
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | About $120 per tire with inner tube and mounting and balancing (plus tax) - radial LT high profile tires (LT215/85R16 - Cooper Tires) | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Stock size on Sweetie is 6.00x16. Your 6.50x16 would face the same situation of supply & demand. Due to accidents, vehicles being modified to use modern running gear, etc. not many vehicles use that tire size any more so each production run is smaller. The cost of each production run has to be spread evenly between the tires produced in that run. Because of that the cost of OEM size tires is a bit higher than one would think it should be. I buy Columbia 6.00x16 bias ply blackwalls locally and pay $100 per tire not counting the tube.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Tim, how tall would those tires be? 29"? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | A 225 70 R16 or 225 75 R16 Would fit the bill quite nicely and are little bit cheaper than the 215's. Alot of smaller SUV's use this size and it is quite common. My Father's shop sells Mastercraft tires, they are basically a generic Cooper, I've had quite good luck with them and they are about 10 to 20% cheaper than most name brand radials. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i buy the traction tires for the rear and a highway sytle tire fot front, i bought mine at Orscheln's for about $80.00 or $85.00. i haven't had any problems with them. Orscheln's is only in the midwest through. i don't know if they'd ship. http://www.orschelnfarmhome.com/ 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 215/85/16 is 30.3" tall, a 225/75/16 comes out to 29.2", and the 225/70/16 comes out to 28.4". The last 2 sizes are fast becoming obsolete, most fitment on those are base model pickups pre-'98 fo the 225/75, and japanese suvs for the 225/70. We almost never sell any of either size, as most of the vehicles that the fit have the option size on them. A 245/75/16 would be a better fit hight wise, and is far more common. They would require a wider (7" ) rim for proper fit. Also, not to stir anything up, but as a tire and alignment professional, I do not suggest running tubes in a tubless tire. It is not safe, especially if you run at highway speeds. I've seen many tire failures caused by doing this.
Bill Burmeister | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Good comments guys!! My heads a spinnin'! Nice safety tip about the tube in tubeless Longbox55!! Who would have known?
What is on "Lucille" right now are four "Firestone Deluxe Champion" 6.50-16's. Gum Dipped - Tube Type with an approximately 3 3/4" whitewall showing. As these tires sit they are ~28" high and ~28 1/2" in diameter on the horizontal. Does anyone have a guess as to their age? I hope to keep this style on her because it just looks so good. Hopefully I'll be able to get something close to these in the future. The thing I'm missing is a spare, thus the reason for this post. I've got a '46 standard 16" rim coming to me and I want to identify a tire size which will work as a spare and and fit on the '46 rim. It really doesn't have to be a white wall. So can someone help me identify the proper size in todays tire terminology that will be close to a 28 1/2" diameter on my old rim? Make sense? I'm such a novice at trying to understand all this tire jargon! I just want to be smart enough so when I go out to get that tire I'll at least sound like I know what I'm talking about!
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | I've got a '46 standard 16" rim coming to me ...... Oops, That reminds me to get to the post office to let you know what shipping will run!!!! Hold tight. I'll get back to you tomorrow on the shipping for that rim. I loaded it up on Sunday and have completely forgot it was in the trunk. Tim
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Can't say what year those Firestone tires are but my brand new Firstone Deluxe Champion 650-16 tires also say gum dipped and made in the USA. Incidentally I love them and for my need and driving would not change to a radial. | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Tim,
Don't worry, no problem! Your busy and probably still dealing with winter up there!
BTW, what size tires were on the rims of that '46 of your and what is your plan for new ones?
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | olblu49, say same as mine! Do you remember where you got them and roughly what you paid for them? Did you get them over the Internet? Do you have a spare?
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I got them last July and paid $607 all told for 4 delivered to my door. Don't forget I am in Canada so we pay more for everything. I bought them from a hot rod/antique car parts place in Vancouver. The spare is one of the old Coopers I had on the truck before. I think these originally came through Coker and on their web site they list dealers so there may be one near you. I can send you a photo of how they look on my 49 if you PM your email address. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Saw your email addy in your profile so sent the photo already. | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | olblu49, Jeez that's a nice clean looking '49 ya got there!! Thanks for the pic! Those tires you show sure would do fine with me for my spare!! I'll check Coker's website and see if I can still get hold of one.
Your right, you all do "pay" extra for being in Canada. Taxes I assume, aye? Makes those tires want to last for a long time! Is olblu a daily driver or is she retired and on "lite duty"?
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | I just bought two of Universal's 6.70-15 bias ply tires for $104 ea. $53 shipping by Fedex to Anderson, SC. (I seem to remember that shipping for 4 tires was going to be about $93) I love that piecrust look on the old tires... BlueDawg
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
| | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Welcome to the Bolt BlueDawg! Sounds like your not that far away from me in SC! Myself and Achipmunk say Hi!  Looks like tires are easily pushing over $100 bucks each no matter where you are! AND shipping is going to continue to climb because of the continued increases in fuel, especially diesel! OK, bias ply....tube or are they tubeless? I'm still getting edge-ja-ma-cated!!
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | Hey back to you and Alvin, Lucille is a beaut! I've got a buddy who bought a '46 last year. He's not working on her yet. He says he just likes to see her smile through the front door of the barn. Love those Art Deco trucks - lots of chrome. I think you can get the old bias ply tires either with tube or tubeless. I got the tubeless. Payday's comin' so I'm ordering two more on Friday. I priced the COKERs also. The blackwalls were $123 ea. Universal also sells a 6 ply tubed tire for $74 each. They're called DENMAN HIGHWAY tires, I seem to recall. The tube is another $13. BlueDawg
Bluedawg
| | | | | Joined: Nov 2005 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 49 | I just received 4 tires today from an antique dealer about 180 miles north of here and got them mounted also today. Thet are the same as Bill's [oldblu49] and they look great. I was looking into radials but they wanted another 100.00 each and I couldn't warrant that for the amount of miles that I would be driving. They are tube tires. Brians40 | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Olblu is a driver, far from a garage queen. She looks nice from about 25 feet away. She is a daily driver from about March until November. I could drive her all year but it would be limited during the winter months and not worth insuring her for that time. I have used her to carry rocks, heavy lumber, garden mulch, soil, truck parts including an old PowerGlide tranny. However I don't abuse her. I had Cooper 650-16 on her before and liked them a lot but they cannot be had up here, hence the Firestones. | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Brian and Bill, Both you guys got great looking Stovebolts with the tires to match!! Looks like Lucille fits right between you guys style wise!! I suppose I do have a partial garage queen, however I do make her perform "lite duty"! Hardware store runs, lumber in light loads, nursery type items, BUT....NO ROCKS!!! Had someone tease me about putting a load of rocks in her just to keep her in shape!! NO WAY!! Bill, I'm sure the rocks you haul are more pebble like!! Not abusive!!  Anyway, back to tires, like Brian, I'm not using my truck that much so I don't need to lay out the money for radials. A tube type would do just fine and right now I need to resolve my lack of a spare issue. After I'm able to correctly define and purchase this fifth tire then I've got the challenge of trying to figure out how in the world I can get hold of the parts needed to store the spare underneath the rear of the bed like it was originally intended. All those parts are missing! BTW, olblu, what is the outside diameter of your tires? I need them to be 28 1/2" in my case. I'm just wondering if you have to be careful about defining the correct O.D. on a 6.50 x 16 sized tire? So far, per this thread, it looks like the best three top sources for the tires needed for a Stovebolt of my era are either Coker, Columbia or Universal. Any other good sources out there just to stay competitive?
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Just measured mine from the ground up and its a hair over 28 inches. Certainly not 28.5". As to my cargo, they were rocks not pebbles. Spent a week with a hammer and dolly taking out the dents before I rattle can painted the bed with - are you ready - FORD Regatta Blue. | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Bill, you know thats a four letter word around here!!  But I guess if you live on a pacific island, that color blue would probably work out just fine!  OK, we must have the identical tire profile. As I said previously, mine measured 28" high from the ground as they sit on the truck and ~28 1/2" on the horizonal diameter. About a 1/2" flat as the tire squishes down from the load. I hope your rocks went to good use considering the sacrific that olblu made!
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | You say that is a FORD letter word? Hmmmm! | | |
