0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#38156 10/04/2003 1:54 AM
Hello,
I am planning on rebuilding a 347 for my GMC and need some help on where to buy parts for it.
Has anyone built one? If so, is there any problems doing this motor.
Also, I need an exhaust for this. I have the manifolds and need the cross pipe, muffler, and pipes.
Thank you for your help,
Bob
#38157 10/04/2003 2:45 AM
i've never built an engine like yours but maybe i can get you on the "hunt". Try egge.com and see what their kits run. i've never dealt with them but hear they are good. I would also check around the parts houses. you would be surprised what the likes of NAPA or Carquest can come up with. As for the pipes i suggest a local shop that does this for a living. They can do it for less than you can buy the pipes and they are custom made. Saves you the skinned knuckles on this one smile
#38158 10/04/2003 12:36 PM
k10 Offline
It's a Poncho, so check oout the poncho sites. I think Kanter may have some stuff but Egge is probably your best bet. Did you score the motor off ebay I sent you?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33615&item=2434227093
http://www.1colorado.net/1957-pontiac/carparts.htm
http://www.vehicleservice.co.za/class/1955pontiac/pages/00000008.htm
#38159 10/04/2003 7:09 PM
A.chipmuck,
Thank you.
K10,
I had this motor awhile. It's time to rebuild.
Thank you.
