1 members (Eileen), 271 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
#380373 02/26/2008 7:44 PM
Apprentice
Apprentice
Has anyone done a chassis swap from an original 1960-62 Chevy Apache 1/2 ton shortbed to a late model Chevy 1/2 ton chassis.
What years works with minimal fabrication?
I have also heard that you can switch the front crossmemeber suspension out from the torsion bar front to late model 5 lug suspension. What kind of issues are there.
You will have to change your frame to a 63-66 frame before you can swap in the newer front suspension. The 60-62 X frames don't work well with the newer parts,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
V
V Offline
I have installed the front K memeber from a 73-80 1/2 ton in a 62 it was pretty much like a 63-66 swap
Apprentice
Apprentice
how much later are you wanting to go?
