| | | Forums66 Topics128,103 Posts1,056,188 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 4 Apprentice | | Apprentice Joined: Feb 2003 Posts: 4 | Has anyone done a chassis swap from an original 1960-62 Chevy Apache 1/2 ton shortbed to a late model Chevy 1/2 ton chassis. What years works with minimal fabrication?
I have also heard that you can switch the front crossmemeber suspension out from the torsion bar front to late model 5 lug suspension. What kind of issues are there.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | You will have to change your frame to a 63-66 frame before you can swap in the newer front suspension. The 60-62 X frames don't work well with the newer parts, Scott | | | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | I have installed the front K memeber from a 73-80 1/2 ton in a 62 it was pretty much like a 63-66 swap | | | | | Joined: Dec 2007 Posts: 34 Apprentice | | Apprentice Joined: Dec 2007 Posts: 34 | how much later are you wanting to go? | | |
