4 members (Hotrod Lincoln, Southerntruck, Rich'sToys, 1 invisible), 83 guests, and 3 robots.
Topics128,090
Posts1,056,373
Members48,442
#380484 02/27/2008 1:04 AM
Quick question, I seem to remember that someone said that toyota copied the 235 chevy. Will any toyota 4.2 liter 1981 parts, such as the exhaust manifold fit my 235 chevy. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
I to have heard that, and am curious as to the answer?
If I remember correctly, although it resembles a GM engine, nothing actually interchanges, just a guess..
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #380529 02/27/2008 2:05 AM
Of all the engines, why copy the 235? Shoulda copied the 292 instead,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Simple, it was introduced before the 292 existed (1955).
Bill Burmeister
Scott
This was done after the 235 was out of U.S. production. It wasn't "they copied", it was "they bought". Run a search for more info.
Cletis #380564 02/27/2008 2:35 AM
I really don't care, Toyota can have them, I was just being smart. Thanks,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
I actually did a little checking aorund. Seems that the 'Yoda engine is actually about 2" longer than the 235. So while it looks like one, it is actually only copied. Not the first time Toyota did that. Their first engine was copied from the 207, with many parts interchanging.
As to the fate of the 235/251? The tooling went ot GM do Brasil, where it was used well into the '70s. I have heard that GM had a plant in Arizona that continued making them in small numbers into the early '80s for service engines for the S.America market. Wouldn't it be cool to find a stash of those engines, still in the crate? Just like those "new" Flatheads that they found in france!
Bill Burmeister
I hope this will clear things up. Japan had many dealings we were not privy too until later. The 235 molds were sold to Toyota and they changed the oiling system and called it the 236.1. Its the same engine with a jap carb and modified head. The 2F motor or called the 4.2L is the 261 Chevy with a japanese head amd carburetion. They lowered the compression to 7.6:1. They usually came with 3.70 gears and got about 10 mpg like my friends sons get with a 4 speed and no OD. He bought my 250 with 9.25:1 and other mods to replace his gas thirsty 2F/4.2 or 261. They should have left it stock with the american head as it would have ran better and got better mileage. I have researched this thoroughly so I hope this info will help. I also checked at more than one machine shop. I believe the 2F was discontinued in 1986. I suppose you could deck the block and mill the head a bunch to bring up the compression or use higher compression pistons to help it out. The jap head is junk but with porting and polishing and finding some way to put on a better carb set up would make a big difference. My friends sons runs good but lacks power big time. Doesn't like hills with such low compression and poor carburetion. Just some info for those who would like to know. BTW Longbox, it would indeed be nice to find a stash of unused 235s or 261s. They are one tough engine. I know that GM made different engines that ended up in Austrailia. Such as the GM Holden car company. Mainly Chevrolet they were but special ones. Some were similar to the ones here but with better compression and other things that made them perform very well along with better mileage. They did make over there an all aluminum block and head 250 Chevy that was a screamer. A machine shop owner here has a friend that has one. There are a few left over there and they eat BB for breakfast. Would be nice to get one and ship it over here. Also the 261 was available in Pontiacs from 57-62. You could get multi carbs on them. That package was not available here but up in Canada they could get them. There has been many deals like this where we got screwed by our own manufacturers and sent stuff over seas we could not have here even before the environ "MENTAL" ist were around. Even a special super high performance slant six was sent to Austrailia and it put out 304 hp. We never saw it here or the turbo diesel version either and several other versions. The best we got was a short time offered Hyper Pack that gave 190 hp. A far cry from the other one.
There are so many different companies involved in the building of vehicles, it'd scare you. Scares. me, and I'm fearless. Was out in the garage just today working on an 80 LUV and saw stamped on the tranny, "Metric, HydroMatic, made by GMC". With an Isuzu 4 banger. Go figure?
dj durant
More pix on Flickr
Tramp #380763 02/27/2008 2:55 PM
homer52 try doing a search of these forums for toyota 235. This topic has been discussed probably 15 times in the years I have been hanging around. Personally I think its another urban legend. headscratch ohwell
Professional Novice
