1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 41 New Guy | | New Guy Joined: Sep 2007 Posts: 41 | I read somewhere that there is a kit to regear the rear end to go faster than 45 mph. Has anybody used this kit? If so, do you still have low end torque for hauling heavy loads? I want to get my 47 AD flatbed to where I can haul tractors to shows with it. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Boy you know if there are gears available I am not aware of them. My 56 and my 64 have the same center section in their rears 6.40 to 1 in high. I get 55 out of them @ 2957 RPM with 10.00 22.5s and late modal V8s
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | What size 45 truck? I guess a 1.5 ton right? No, no kit that I know of. If you are up for an entire axle swap then you will have some options. Check out my pictures on the link below, covers a few different axle swaps. What engine do you have? If it is only a 216 then faster gears will only hurt you while hauling a tractor, unless they are pedal tractors  To go fast and haul a load you need power.. Grigg | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Someone here did an axle swap that might interest you. With some searching you may find it.
The guy cut the ends of the axle housings off the stock axle, and put those ends on a newer axle. He was then able to use the original hubs and brakes, while having a much more highway friendly axle ratio.
Obviously I've simplified the process a bit.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | what about a 2 speed axle? 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | what about a 2 speed axle? The benefit of a two speed axle is a slower gear, not a faster gear. Some modern two speeds have good fast ratio choices, but they are generally two big and heavy to be a good candidate for swapping into our old trucks. Grigg | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | ok, thats good to know, i didn't know exactly what a 2 speed rear end was or how it all works. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | That ebay auction appears to be a Rockwell rear axle from a Chevy 3500HD. If I am guessing correctly it has 10 lugs on 7.25" circle, like your truck. He calls it a "10 bolt" but it is not the GM axle most people call a 10 bolt same falily as a 14 bolt, it appears to be a Rockwell.
It is not a great idea to put Disc brakes on the rear without having them on the front too.
If he has the rest of the front axle, I see hubs and calipers in the picture, then that would be an option too (after narrowing).
For the price he is asking both front and rear axles should be included and in great shape..
Grigg | | | | | Joined: Jan 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 66 | Hi all, When I was looking at gearing up my truck, I came across this website that has some of the 5.43:1 gears for the 1.5 ton rear end. http://www.vapinc.com/ringandpinions/main.html They're pricy,, but looks like some are available. Jon
Jon
