9 members (Steelonsteel, 55shaker, GRNHydra, WICruiser, 51sub, Wally / Montana, Peggy M, Hotrod Lincoln, 1 invisible), 108 guests, and 2 robots.
Topics128,141
Posts1,056,471
Members48,441
#379661 02/25/2008 2:00 AM
Ok I admit it . These doors are kickin my Tail. I work on other projects on the 1949 burb and always the doors are stacked in the corner giving me an evil grin smile I am now to the point they need to be reattached. I have installed new felt channel, inside and outside whiskers/rubber, and put in new regulators. I have new glass and the "slide" attached to the bottom. What is the procedure to get it into the door cavity and onto the regulator? Any comments or pictures would be greatly appreciated. Thanks as always.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
I was in your boat ...I went this way ..I first installed the rear strip and vent window an glued it all in usin the window itself as a guide to hold the trim till it cured runnin it up by hand from the bottem.
After the trim was where it should be ..i then had to remove the vent window an its long slider ..I got the glass in the door ..an fished the vent window into a its semi permanent place you will have to wrangle your regulator in there NOW ..get it in the window channell.
Now set your wing window an bolt it down ..now that the window is captured in BOTH felts , now mount your regulator solid .
that worked for me
1952 Chevy Shortbed
Photos in Photobucket
My 49 does not have vent windows so I dont have the ability to take out vent side channel to put glass in. Anyone else have a suggestion? is it possible to take regulator out, put it together the reinstall regulator?
On Ebay and some of the vendors they sell a cab manual for things like doors and windows it was written in 1947-48 and works for all cabs to 1950. I bought one and would recommend it. However if you can't find one send me an e-mail and I will mail you photocopies.
If your asking how to hook the glass channel to the reg.
The reg goes in last, Put the window in the truck then put the regulator in from the bottom. Put the rollers in the channel and bring the whole unit up to attach the screws to the reg.
not the easiest to do but can be done.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
You can also get one that goes from '47-'51 from THE FILLING STATION for $9... part number DG-62
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Thanks Wilbur. I will try your method and see what happens.
49, I'm headed out for a while tonight, but when I get back I'll send you an email with scans from the manual I have that shows you how to get the glass in. It's relatively simple.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Tom R thanks please send to [email protected]
49, I just sent the scans, but they total over 6Mb. If you can't open them (two scans @ 3Mb each). I can re-send them seperately, and maybe that'll work. I don't know why scans take so much memory.
1948 Chevy 1/2-Ton
Oops! I sent the e-mail to the address in your profile. I'll try breaking it down and re-sending them to your gmail account.
1948 Chevy 1/2-Ton
I sent the scans a few days ago. Did you get 'em?
1948 Chevy 1/2-Ton
Book arrived today... another product misrepresented! The book does not cover '51 as advertised. I fail to what's so difficult about this people... '51 doors are the ONLY year with vent windows and pull down door latches.
The book actually covers 47-50 and has all the info you need to deal with any aspect of your doors... as long as you don't have vent windows.
Woody
Door Art Collection
