7 members (TUTS 59, Bill Hanlon, greenie-reddy, Shade Baby, dt235sd, DougH6100, Rusty Rod),
87
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,887 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 34 | OK,
I bought the standard made-in-who-knows-where rolling car jack from W*l-M*rt a while ago (the $19.95 kind). The thing barely lifts a regular minivan. By now it makes some wild krrrck! noises when I lift anything. Luckily the recycling yard for scrap metal is less than a mile away.
Assuming I wanted to buy a rolling car (and truck) jack that would last for the rest of my life*, but not want to get a second mortgage for it, which one should I buy?
Andy
* Assuming my current car jack won't kill me. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Drop the bucks and buy a Walker. Will cost some bucks but will last a life time in the home shop, leave the China junk for the want'a b's and fools. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | As a rule I don't buy anything that my life or livelihood depend on from HF or other cheap chineese suppliers. There are some quality chineese made tools buy not many. Get a brand name jack. Don't bet your life on cheap. I'm not sure who makes it but NAPA sells a good jack too.
| | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | I bought a 3 ton jack from Advanced Auto, and have had it about 5 years, so far, so good. In the past, I had a Walker 2 ton, and a Viking 3 ton that were also bought new and both ended up leaking. Some of my friends have had good luck with the Craftsman brand jacks.  Now, I try and look them over well to try and judge the quality. If you buy the cheapest one that you can find, you will most likely be disappointed. BTW: The Walker was made in the USA, and the Viking was a Brazil made unit. It's too cold outside right now to go look, but I would bet that the 3 ton that I got from Advanced Auto is most likely an import and so far has performed well. Whatever you do, don't buy a jack that is undersized for what you will be mostly using it for. They will usually lift at least a little more than they are rated at, but won't last as long. John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jan 2007 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 48 | Some good info about jacks on this site. www.hyjacks.com/H2.HTM | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | 4 post lift would be nice | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Ive had my 3 ton Craftsman floor jack for near 15 yrs an it works great to this date . it was like 89.99 back then | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I have a couple of 3 ton jacks.
I also buy those KaMapART type cheap jacks at Menards for $15. They come in a small plastic case so I can stick them in the back or behind the seat. Great in a pinch, but not good for normal use. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I have had my Craftsman 1 1/2 tonner since 1973,and it still works like new.At that time Craftsman jacks were made by Blackhawk.Although it is rated at only 1 1/2 tons it will pick up any car or light truck.I dont know about the new Craftsmans,but the Walkers have a very good reputation.Most repair shops I go to use Walkers. | | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | I did get the specs off of my jack today (it finally warmed up outside). MVP Pro-Lift 3 ton Hydraulic Garage Jack Model G-593 BW 5 3/4" - 20" Lifting Height Made in China  Purchased from "Advance Auto" for about $60-70 All I can say, is I have owned it over 5 years, and it still works great. John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I've got a Jet, that I've had over 10 years. Paid about $90. It works great and one time when it needed fluid and I couldn't find the manual, I called them up and they talked me through it and sent a manual. Later I found mine. Highly recommended based on performance, durability and customer service. | | | | | Joined: Nov 2007 Posts: 131 Certified Bolt Nut | | Certified Bolt Nut Joined: Nov 2007 Posts: 131 | If you look at Sears.com, the craftsman jacks look to have started a downward slide in quality. The reviews aren't very good. I picked up the 2-1/2 ton with two stand kit for 29.99...just couldn't pass it up for an extra jack. It has worked well so far, but I'm not trusting my life with it just yet. I say spend the extra money and get a proven jack..its one of those tools that's worth the money | | | | | Joined: Dec 2007 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 58 | I was asking the same thing a few weeks ago. Any of the new sears jacks are garbage. Spending a few extra $ is the way to go. Got a 3 ton jack from NAPA that is built like a beast. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Who builds the jacks that NAPA sells? | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | My boys bought mine from sLowes,(luv Fathers day) it's Kobalt and it's 3 ton and came with a set of stands for less than $90. It's also 1 touch lift.Works great now for 5 years. | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I have a Hein-Werner, it is old (I have had it for over 45 years) and still works great. They are the standard of quality that all jacks look up to. It has lifted everything I have owned or worked on and never let me down unless I turn the valve. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have always liked Hein-Werner and Walker.One of my 2 1/4 ton Hein-Werner floor jacks is down with a bad pump seal.A good set of jack stands are a must to be safe.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Amen on the jack stands.No matter how good of a jack you have I would not trust one if I was under the vehicle.Better safe than sorry. | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | I bought a 3 ton at SAM's club for a little over $50. It's not the light weight competition aluminum but so far it has been working great. Only had it about 3 years however. | | | | | Joined: Dec 2007 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 58 | Who builds the jacks that NAPA sells? Couldn't find a company. Just said it was built for NAPA. The thing I like about that jack is that it has a rebuildable pump. | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | They rate those cheap throw-away jacks the same way they rate the horsepower on cheap throw-away air compressors. I have had one of the older Craftsman jacks for more than 25 years. I've used other jacks that other guys had and never thought there was much difference. I managed to get a Walker a couple of years ago and have been able to compare them side by side. They both will lift a car or truck with the same amount of ease. There are two features that make the Walker better. They both have roughly the same size lifting pad, but the Walker is square, giving a slightly wider reach. The Walker pad drops down slightly below the level of the wheels whereas the Craftsman is well above them. This can be very useful, getting under something that's very low or pulling a engine or transmission out from under a car. The other thing is how well the Walker rolls. I don't mean just across the concrete, which is nice too. The jack pad, when you raise it up high, swings in an arc toward you. That means the jack has to roll under the car and the Walker does that with much more ease.
'67 GMC 3/4 292 4spd
| | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | I have a powerbuilt 3 ton. I have had it for about 3 years. It will pick up the front end or rearend off a pickup easy
Now boltless but looking 1951 F-1 350/350 1965 Mustang 355 glide 1971 F-100 401 fe it hates me 1972 Maverick 302 c4
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I buy 3 1/2 ton floor jacks from costco for about $80. They lift one wheel of our 18 wheelers, which of course is more than they were designed for. All floor jacks I have ever seen bypass when you try lifting much more than their rating. When that happens, we roll out a 22,000 air over hydraulic which is OTC but also made in off shore. I have bought some of them new on ebay for $400 where an Ameican made is over $1500. I hate chinese stuff but there are times it is much more cost effective than American made. When the 3 1/2 ton costcos start leaking down, we take them back to costco and get another one. No questions asked, but they want the original receipt. I used to take Hein Werners and Walkers to authorized repair shops in San Antonio and wait a month and pay as much as a cheap jack in repair charges.
| | | | | Joined: Feb 2008 Posts: 85 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 85 | I bought a craftsman 4-ton w/stands about 7 yrs ago. The stands are still working great (Still under the same camper...) but the jack crapped out about 5 yrs ago. It did lift my sisters BMW Z3 the other day, but it wont lift an SUV! I still have it thinking that I might replace the seals one of these days, but haven't yet. About 4 yrs ago I bought a Larin 2.5 ton (from a FLAPS) and it rides in the truck with me currently. It wont pick up any of my truck tires but comes in handy for many other things... I recently played with a 2-ton bottle jack/stand combination that works really REALLY well!!! (Northern tool) I have always had the issue with bottle jacks that they were unstable, NOT THIS ONE!!! I'm now looking for a 5-Ton version to carry in the rig with me!!! Laterz, Gator >|--|~ | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | I bought one of the red- skyscraper looking farm truck jacks- Never had a problem, and I always use jack stands if it is going to be jacked up more than 5 minutes, or I am going anywhere under- even if just for a quick peak- My life is worth the extra few minutes to set up correctly.(yours probably is too . . . .  )
| | | | | Joined: May 2008 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 24 | I bought a $100 dollar jack from farm&fleet about 16 years ago and it still goin strong | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Use a Craftsman 3 ton and have had no problems for 6+ years now.
Hank | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I have cheapies from menards to use in case I have a flat. They came in a plastic case and I throw them behind the seat. I wouldn't use them for every day use though. They are just easier than the factory jacks in an emergency. For my shop I have larger (3-5 ton) jacks for every day use. My favorite has a single pump quick rise (until you get it to the frame), and a second hand lever quick pump near the jack so you can get it situated quickly without using the long handle. I also have a Craftsman 3 1/2 ton I have at another building that I bought used from a firend who was moving. It works fine but it has a shorter height. I like to get my vehicles up high to work on them. I use "good" heavy duty jack stands too. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I have an original GM for my 49 but would not consider using it on the road. I bought a bottle jack which works well but could be unstable. I am looking for something else that I can carry in the tool box in the bed of the truck. I noticed the jack from my 81 Malibu might do the job. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Jack stands are a must you say?? This is a picture that I've seen posted here and around the net several times. http://www.pbase.com/dennygraham/image/130293613 He orta be the poster boy for the Safety Councils Calendar. DG
Denny G Sandwich, IL
| | | | | Joined: Oct 2005 Posts: 4,259 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,259 | Well............at least he chocked the wheel. | | |
