| | | Forums66 Topics128,187 Posts1,057,316 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Looking at buying a 46 COE. The truck is about 3 1/2 drive from me so I'm trying to get some things sorted out before I take a ride to check it out. Owner told me today that according to the casting #'s that it has a '56 261 engine in it. I asked about the carb and he said that it has an updraft style carb in it and the air cleaner assembly is all complete. Would a 261 fit in a 46 COE or would it take some metal work to fit length wise? From the searches I've done I think the 261 is 1 1/2" longer. Thanks Don | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Don, the length of the 261 is the same as the 216 and 235. It's the GMC engines that are longer. | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Don, if that is the only difference, I don't see why it wouldn't fit. This is a picture of my frame and 235 engine. I guess it would be better if the 1 1/2" were toward the rear. Hope this helps, Bill http://rides.webshots.com/photo/1534274130083734483yLGLWW?vhost=rides | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | DONT FORGET YOUR CAMERA!  Other then that, join the club!  As already stated no difference in length with the chevy engines. Id crawl under and get the casting numbers if you do go peak at it then check the inliners sight to be sure. Chevy should have a Carter updraft carb. Any other stuff you want to know before you take the trip? Jeff | | |
