3 members (Charles in CA, Bill Hanlon, Gdads51), 107 guests, and 3 robots.
Topics128,186
Posts1,057,309
Members48,468
#375442 02/14/2008 11:26 PM
Looking at buying a 46 COE. The truck is about 3 1/2 drive from me so I'm trying to get some things sorted out before I take a ride to check it out. Owner told me today that according to the casting #'s that it has a '56 261 engine in it. I asked about the carb and he said that it has an updraft style carb in it and the air cleaner assembly is all complete. Would a 261 fit in a 46 COE or would it take some metal work to fit length wise? From the searches I've done I think the 261 is 1 1/2" longer.
Thanks Don
don stocker #375484 02/15/2008 1:22 AM
Don, the length of the 261 is the same as the 216 and 235. It's the GMC engines that are longer.
don stocker #375486 02/15/2008 1:24 AM
Camp Commandant
Camp Commandant
Don, if that is the only difference, I don't see why it wouldn't fit. This is a picture of my frame and 235 engine. I guess it would be better if the 1 1/2" were toward the rear.
Hope this helps,
http://rides.webshots.com/photo/1534274130083734483yLGLWW?vhost=rides
~ Billy
1959 GMC 860 | Pictures
Bill Marlow #375620 02/15/2008 7:01 AM
DONT FORGET YOUR CAMERA! wink
Other then that, join the club! smile
As already stated no difference in length with the chevy engines. Id crawl under and get the casting numbers if you do go peak at it then check the inliners sight to be sure.
Chevy should have a Carter updraft carb.
Any other stuff you want to know before you take the trip?
Jeff
My 1953 Chevrolet
1947.1 Gallery
