7 members (fonz8261, jmoore, Hotrod Lincoln, Woodcmiami, Ludwig.van.dille, Shaffer's1950, 1 invisible), 73 guests, and 1 robot.
Topics128,077
Posts1,056,280
Members48,441
#374137 02/12/2008 3:27 AM
Going through all my misc nuts and bolts I came across two flat washers. They are 1 1/4 O.D. with a 3/8 hole and there are 5/16 thick with the Chevy bowtie stamp on them. Iam going to use them for washer on top of my 216 stubs that hold down the valve cover. I have no idea where I got them.
Anybody know what they were for ?
Ex Hall Monitor
Ex Hall Monitor
No idea. 5/16" thick is mighty thick for a washer. I'm betting they're a spacer of some kind. If you don't get an answer to your query here you might try over at the VCCA site.
I had the same on my '46 and I thinnk they came from my front motor mounts.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
They go to the johnson rod
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Nah Brian, they space out the muffler bearing mounting bracket.
66 I think you are thinking of the 1/4" thick washers.
Brian Moore
woops, maybe I am Brian headscratch
Moderated
Moderated
Found these washers with my front motor mount parts from my '41 Chevy 3/4 ton truck. After cleaning everything up, discovered the bowtie on the washer. Now I am trying to remember how it all goes back together. Replacing the 216 with a '60 235 and S-10 5 speed.
I found the same bowtie marked washers on an unmolested 1942 1 1/2 ton truck. They were used on the lower 2 bolts of the front motor mount. The only markings I ever recovered.
Lots more pictures
You got it Paul, they are standoffs at the front motor mount:
http://www.pbase.com/dennygraham/image/149005339
DG
Denny G
Sandwich, IL
