3 members (klhansen, ronsway, 1 invisible),
165
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 20 New Guy | | New Guy Joined: Feb 2008 Posts: 20 | Going through all my misc nuts and bolts I came across two flat washers. They are 1 1/4 O.D. with a 3/8 hole and there are 5/16 thick with the Chevy bowtie stamp on them. Iam going to use them for washer on top of my 216 stubs that hold down the valve cover. I have no idea where I got them. Anybody know what they were for ? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | No idea. 5/16" thick is mighty thick for a washer. I'm betting they're a spacer of some kind. If you don't get an answer to your query here you might try over at the VCCA site.
| | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | I had the same on my '46 and I thinnk they came from my front motor mounts.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | They go to the johnson rod
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | Nah Brian, they space out the muffler bearing mounting bracket. | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | 66 I think you are thinking of the 1/4" thick washers.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | woops, maybe I am Brian  | | | | | Joined: Jan 2014 Posts: 2 Moderated | | Moderated Joined: Jan 2014 Posts: 2 | Found these washers with my front motor mount parts from my '41 Chevy 3/4 ton truck. After cleaning everything up, discovered the bowtie on the washer. Now I am trying to remember how it all goes back together. Replacing the 216 with a '60 235 and S-10 5 speed. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I found the same bowtie marked washers on an unmolested 1942 1 1/2 ton truck. They were used on the lower 2 bolts of the front motor mount. The only markings I ever recovered. | | |
