| | | Forums66 Topics128,022 Posts1,055,386 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 9 New Guy | | New Guy Joined: Feb 2008 Posts: 9 | I recently acquired a 1939 Chevy pick-up to complete the already started work of a streetrod.
From the paperwork I received with the truck it looks as though it is 1939 chassis with a 1940 cab.
I haven't seen too many pictures of the diference in the actual dash layout. I also have questions about how the windshield mounts but that will come later.
How do I tell the difference between a 1939 and 1940 dash layout?
Any information is greatly appreciated.
It's never too late to relive your childhood or get your hands a little greasy.
Thurl "TC" Carmany
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | If you are talking about trucks it is simple. 39s used round guages same as 37 and 38. 40s used a rectangular guage cluster same as 41-46. | | | | | Joined: Jan 2001 Posts: 7 New Guy | | New Guy Joined: Jan 2001 Posts: 7 | [39s used round guages same as 37 and 38. 40s used a rectangular guage cluster same as 41-46.]
This is true, however my 1940 School bus had the round dash gauges. I figure since it would have been a chassis/cowl combination, no cab, that Chevy was just using up their 1939 inventory.
Due to modifications I made to the steering and dassh, I ended up smoothing it and relocating aftermarket gauges. (long story) | | | | | Joined: May 2006 Posts: 2 New Guy | | New Guy Joined: May 2006 Posts: 2 | I would say that round gauges can be found in an '40 or later is absolutely correct in a cab and chassis.. from personal experience I have even seen the round gauges in a '41-'46 model school bus sitting in a junk yard..
'40 1/2 ton streetrod, '40 1 1/2 ton, '63 1 ton, 49 studebaker 1 ton pu
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | From what Ive seen looking through the 1941 Chevrolet Restoration Pack the gauges in a cab and chassis models were a completly different beast then the trucks.
I do not believe the round gauges are the same as the earlier pre-40 dash setups. Hence the 1940 trucks would have a rectangular setup while any of the cab and chassis or custom bodied trucks had a different round gauged setup. | | | | | Joined: Feb 2008 Posts: 9 New Guy | | New Guy Joined: Feb 2008 Posts: 9 | Well, then I guess it is a '40 cab on '39 chassis as I suspected.
Thanks for the info.
I've been reading Stovebolt forum for days now and I'm in awe at all the info. Glad I stumbled on this website.
Thurl "TC" Carmany
