2 members (Bill Hanlon, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,679
#373398 02/10/2008 4:06 PM
I recently acquired a 1939 Chevy pick-up to complete the already started work of a streetrod.
From the paperwork I received with the truck it looks as though it is 1939 chassis with a 1940 cab.
I haven't seen too many pictures of the diference in the actual dash layout. I also have questions about how the windshield mounts but that will come later.
How do I tell the difference between a 1939 and 1940 dash layout?
Any information is greatly appreciated.
It's never too late to relive your childhood or get your hands a little greasy.
Thurl "TC" Carmany
TC40Chevy #373575 02/10/2008 11:08 PM
If you are talking about trucks it is simple. 39s used round guages same as 37 and 38. 40s used a rectangular guage cluster same as 41-46.
[39s used round guages same as 37 and 38. 40s used a rectangular guage cluster same as 41-46.]
This is true, however my 1940 School bus had the round dash gauges. I figure since it would have been a chassis/cowl combination, no cab, that Chevy was just using up their 1939 inventory.
Due to modifications I made to the steering and dassh, I ended up smoothing it and relocating aftermarket gauges. (long story)
Member #719
1940 Chevy School Bus
Imagination is more important than Knowledge - Al Einstein
Y
Y Offline
I would say that round gauges can be found in an '40 or later is absolutely correct in a cab and chassis.. from personal experience I have even seen the round gauges in a '41-'46 model school bus sitting in a junk yard..
'40 1/2 ton streetrod, '40 1 1/2 ton, '63 1 ton, 49 studebaker 1 ton pu
yenko32 #376686 02/18/2008 1:29 AM
From what Ive seen looking through the 1941 Chevrolet Restoration Pack the gauges in a cab and chassis models were a completly different beast then the trucks.
I do not believe the round gauges are the same as the earlier pre-40 dash setups. Hence the 1940 trucks would have a rectangular setup while any of the cab and chassis or custom bodied trucks had a different round gauged setup.
My 1953 Chevrolet
1947.1 Gallery
Well, then I guess it is a '40 cab on '39 chassis as I suspected.
Thanks for the info.
I've been reading Stovebolt forum for days now and I'm in awe at all the info. Glad I stumbled on this website.
Thurl "TC" Carmany
Moderated by  ndkid275, Phak1
