2 members (porsche, Uncles51),
55
Mod | | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 94 | I'm heading to a local junk yard on Saturday to get a grill and a couple of fenders for my '50. I started to take my front end off of my truck last night, and realized that it's a little more complex than I thought. Fifty eight year old bolts don't like to co-operate, even after being soaked in PB Blaster for a couple of days. I ended up getting a bunch out, but also snapped a few as well.
Does anyone have any suggestions to getting a grill off at the yard? My one idea was to take a cordless sawzall and cut around the fenders and lower rad support. I really don't like to do it, just because I'm probably going to feel horrible for cutting up the fenders. ANY suggestions would be much appreciated. Thanks. | | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | I've taken rusty bolts off of farm equipment with a hammer and cold chisel. Its how I removed the mounting bolts from the extra set of rear springs that I have in my garage.
I've watched dad do this one on our tractor, tighten the bolts up as much as you can, and then back them off and they should break free.
One thing I always take with me to the junkyard is a pipe wrench, a breaker bar and a BFH or two
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Take a cordless drill and some sharp bits. The grill boltheads can be drilled out then knocked off with a chisel fairly easily.
| | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | One of the main reasons why a lot of yard owners don't allow the public to remove parts anymore,(other than liability), is because of people butchering up good parts that are in the way to remove something else. Be respectful of what you do and how you act in a yard that still allows it. It'll pay you back in the long run.
Bob | | | | | Joined: Oct 2007 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 94 | I don't plan on cutting any fenders if they are good. If they are completely rotted it out, though, I'd do it. Either way, I'd still feel horrible. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I agree with Martin. I usually take my cordless drill with me. | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Try tightening them til they break. You can always work on getting the rest out when you get home.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Try a cordless dremel tool. And get lots of reinforced cutting wheels. I'd personally opt to cut the bolts rather than any sheetmetal.
Another thing you might try is heating the nuts with a propane torch and then try breaking it loose with a socket and wrench. If worse comes to worse, you'll just shear the bolt in half.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | If possible, don't bother fighting the rust and tighten until they snap | | | | | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | I found that if you are quick you can snap the bolt with little effort for usally the head is rusted to the sheet metal. This is advice for the blasted flat head screws with a nut on the bottom. I had a ton of those on my I sure alot of them weren't orginal but replacements but the heads were so soft they stripped instantly. It became easier to snap them then spend 20 minutes grinding them off. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Don't forget your visegrips. You're lucky you have a "junque" yard with ADs in it close by.
~Jim
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | TimK, where do you live in Indiana? | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I agree with the tightening until they snap. Although one of the yards I go to will remove it for $10 (they send the guy with the truck, air tools and torches).
Scott
| | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Do as BJR said, and it'll pay off in more ways than you can think. Remember, be careful of whose toes you step on in life...they may be attached to the butt you have to kiss later on. Cold chisel and a BFH works great when you're out in the yard. | | | | | Joined: Oct 2007 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 94 | Thanks for all the input guys!! I really appreciate it. I really didn't want to cut anything, but that was the only "quick, easy" way that I could think of to get one off at the yard. I'll definitely be taking a cordless drill and chisel now. Oh, and can't forget the BFH. I've got a nice size one that I think will help out a bit. Thanks again. | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | I agree with Hot Rod Dad about the cordless Dremmel tool. That's what I used to take some of the grill screws off my truck. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | You might try a combination of these tactics and see which works best for the situation. Better to come prepared with too many tools rather than not enough. | | | | | Joined: Oct 2007 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 94 | I was kinda planning on taking whatever I thought could be useful, along with a lot of muscle. Hopefully all will go well, and I'll come back with the parts that I need. There's supposed to be at least 20 or so trucks like mine, even panel wagons and such, up there. Guess I'll have a bunch to choose from. | | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | Don't limit yourself to battery tools.
I take the big swap meet wagon loaded with a 12 volt battery and a 12 volt power inverter and 120V tools. I drill out the big rivets and stubborn bolts and then use the reciprocating saw and grinder as required. 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | | | | Joined: Sep 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 42 | Junk yard should have a gas axe (acetelene torch). Just heat up the rusted in bolts a bit, and put the wrenches to them. Usually works like a charm. | | | | | Joined: Dec 2007 Posts: 166 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 166 | Theres a product caled " move-it " that seems to work extremely fast. Beats WD 40 by a landslide. I would spray the bolts here and there wherever ya can,...finish the coffee ya came with, light one if ya got one, wait a few minutes and start a crankin,....good luck. | | | | | Joined: Feb 2008 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 81 | Whatis a BFH? Sorry, but I have no idea what you are talking about. | | | | | Joined: Jan 2008 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 39 | | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | How about an update,did you get your parts??? -------------- Floyd
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | |
