2 members (Waveski, Greg_H), 79 guests, and 3 robots.
Topics128,184
Posts1,057,267
Members48,467
I
I Offline
I was on a website that showed good and bad reviews equally on these batteries. I have a 350 engine. I also want to add ALL the bells and whistles to my project bus. Is 875 cranking amps sufficient juice, and can someone tell me any experiences or heard of any from these batteries ? Thanx alot ! Cheerz !
IsolationRide,
That is a hefty amount of CCA. That figure will only come into the equation as you start, or try to start your engine. It allows you to crank for 30 seconds at 0&deg and not drop below 7.5 volts (I think).
If your engine doesn't start after this ordeal, you have serious problems elsewhere.
The CCA won't figure into the "bells & whistles" formula as much as the rated output of your alternator. With lots of goodies on board, you will want a high output charging system.
Stuart
I
I Offline
Well,...here in the Great White North....sounds like I found the right one !...lol. I,ll check out some alternators that will give me my high output. Thanx atomarc !
Just a thought, but I would also check out using one of the high torque starters, like Hitachi or Proform, both of which I have used. Even if your engine is not high compression ratio, these high torquers are gear driven, which really whip the engine over zero weather at the same CCA as you would use for a normal starter. The only drawback is that they are more expensive than factory, but I think they are well worth the expense for reliable cold weather starts.
IsolationRide,
My post wasn't correct..you indicated cranking amps or CA. My reference was to cold cranking amps or CCA. I think CA is measured at 32&deg. The point I was trying to make is that lots of electrical do-dads will impact the system as the rig runs, which is charging system territory.
The oink in the battery is relevant to spinning the engine over during a start...basically.
Stuart
How does this one look to you?
New Factory DELCO 145Amp ALTERNATOR Chevy GMC Truck Van
Also fits most 1999-2007 Sierra Suburban Tahoe & Yukon
US $78.00 - with the CN $ at an all time high it's probably less than that to you.
It's at http://stores.ebay.com/Truck-and-RV-Supply_W0QQcolZ2QQdirZQ2d1QQftidZ2QQtZkm
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Sorry I posted this before remembering the e-bay Forum rule. I tried three times to delete it but no luck so can one of the Moderators please do so? Thank you.
Dave
I have a 350 in both my trucks and upgraded to a high torque starter from Summitt. I also ALWAYS use Optima Red top batteries because you can mount them anywhere, never need to vent them and you can drain them down to nothing with out major problems (if you are an idiot like me and forget to turn your lights off).
I would rather a beefier starter than a battery or a mix of both worlds like I mentioned.
