Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (jay d, 2 invisible), 54 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#36550 09/18/2003 5:32 PM
I was in Calagary Pick-a-Part the other day, perusing parts as usual. I came across a 1967 Chevy 3/4T that had the STRANGEST stovebolt I have seen so far! Most of it was standard (a 250, I think), but the rocker cover had 2 extra bumps over 1+2, and 5+6. It also had more oil breather plumbing than ANY engine I have ever seen. There were 1/2" tubes in and out of the rockers to the point you almost couldn't set the top of the engine. Each tube had a small filter(?) about half way along. It was a real snake nest. Any idea what engine it might be and what all the tubes were for? Not life and death, it just sparked my curiosity. Next time I go, I'm taking my camera.
#36551 09/18/2003 6:41 PM
It's a 250 , have one in my 81 1/2ton It has the intergral head and is just emission stuff.
Tommy
59 apache 1/2t
261 short stepside
#36552 09/18/2003 8:53 PM
STAY AWAY FROM THOSE ENGINES,,,,You may be able to do something with the block and lower end but the head up it is dead :rolleyes:
#36553 09/19/2003 12:40 PM
I got a 292 from a '67 3/4 ton stepside (ex Forest Service) and rebuilt it in '77. It had one lifter cover that had a capped off 1/2" tap above the #5 bolt hole. Santucci mentions modified sidecovers for external drainback and pan ventilation, but he's talking drag racer mods-- I think you have a heavy duty truck application that had an oil bath air cleaner. Very obsolete.
BTW, I'm using the modified /capped side cover at the rear. Can't hurt and it's different. And I'm too cheap to buy a new untapped sidecover.
Every 25 years I like to rebuild that 292 just for GP
