0 members (),
40
10
Mod | | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36550 09/18/2003 5:32 PM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | I was in Calagary Pick-a-Part the other day, perusing parts as usual. I came across a 1967 Chevy 3/4T that had the STRANGEST stovebolt I have seen so far! Most of it was standard (a 250, I think), but the rocker cover had 2 extra bumps over 1+2, and 5+6. It also had more oil breather plumbing than ANY engine I have ever seen. There were 1/2" tubes in and out of the rockers to the point you almost couldn't set the top of the engine. Each tube had a small filter(?) about half way along. It was a real snake nest. Any idea what engine it might be and what all the tubes were for? Not life and death, it just sparked my curiosity. Next time I go, I'm taking my camera.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#36551 09/18/2003 6:41 PM | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | It's a 250 , have one in my 81 1/2ton It has the intergral head and is just emission stuff.
Tommy 59 apache 1/2t 261 short stepside | | |
#36552 09/18/2003 8:53 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | STAY AWAY FROM THOSE ENGINES,,,,You may be able to do something with the block and lower end but the head up it is dead :rolleyes:
#36553 09/19/2003 12:40 PM | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | I got a 292 from a '67 3/4 ton stepside (ex Forest Service) and rebuilt it in '77. It had one lifter cover that had a capped off 1/2" tap above the #5 bolt hole. Santucci mentions modified sidecovers for external drainback and pan ventilation, but he's talking drag racer mods-- I think you have a heavy duty truck application that had an oil bath air cleaner. Very obsolete. BTW, I'm using the modified /capped side cover at the rear. Can't hurt and it's different. And I'm too cheap to buy a new untapped sidecover.
Every 25 years I like to rebuild that 292 just for GP
