1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 34 | Can I use pressure-treated wood for a truck bed?
Andy | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Some of the new stuff is really hard on steel, think rust and corrosion, and thus would be a bad idea.
I would not use either the new stuff or the old stuff, just regular wood chosen for it's rot resistance, like white oak, or southern yellow pine, or a number of the imported woods sold as semi trailer flooring, and some good stuff is even sold as decking for around your house.
Grigg
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I think most of the pressure treated wood is softer species. Hrad stuff like Oak won't absorb chemicals very well. If wear not a concern, PT would be OK. All your cuts and holes will need to be treated before installation or it will rot out there. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | The only problem i see with PT would be since the outlawing of Arcenic a number of years back all modern PT wood is Salt impregnated ...Salt and any thing Metal will prob lead to corrosion issues when it gets wet. Tim | | | | | Joined: Feb 2000 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 69 | Pressure treated wood is typically made of softer species and is always the lowest grade of lumber. That is lumber that is too small or immature to be used for regular building. It is essentially junk or near waste wood; don't use it. | | | | | Joined: Nov 2007 Posts: 131 Certified Bolt Nut | | Certified Bolt Nut Joined: Nov 2007 Posts: 131 | Most pressure treated wood here in Texas is #1 or #2 Southern Yellow Pine. About 4 years ago the old CCA (Chromated Copper Arsenate) was replaced for a new formula ACQ (Alkaline Copper Quaternary). ACQ requires either galvanized steel or stainless because it is much more corrosive than the old CCA. I sale lumber for a living, and would not recommend using ACQ treated wood for anything that is in contact with painted steel. Even joist hangers that are used with ACQ have to be galvanized. Unless you want bigger problems later go with some form of untreated YP or something harder like Oak. Just my 2 cents. | | |
