| | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 3 New Guy | | New Guy Joined: Sep 2007 Posts: 3 | I have the chance to pick up a pair of nice boards cheap!!! The guy says they are 72" from a 47 3100. I have a 50 3600 does anybody know they'll fit. another new guy | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | A 3100 is a 1/2 ton. A 3600 is a 3/4 ton which is longer than a 1/2 ton,,so, no they wont fit. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have the chance to pick up a pair of nice boards cheap!!! The guy says they are 72" from a 47 3100. I have a 50 3600 does anybody know they'll fit. another new guy Measure it, then you'll know for sure.
| | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | I have a pair of 3/4 ton boards and they measure 71 3/4 along the top edge that goes under the cab. The 1/2 ton and 3/4 ton are different lengths. Hope that will help
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Rabbit: Welcome to the Bolt. Lots of good folks and info here. I dropped you a PM regarding running boards. | | | | | | Houston54 Unregistered | | Houston54 Unregistered | The 3100 (Q/2 ton running boards have a length of about 67". The ones you are describing as being 71" are for a long bed truck. | | |
