6 members (Gdads51, Bill Hanlon, WICruiser, classicfins, Rick Brown, Youngin' Tut 59), 141 guests, and 1 robot.
Topics128,115
Posts1,056,594
Members48,448
#363061 01/20/2008 3:40 AM
Are the brake and clutch pedals on a ’41 supposed to be the same height?? My clutch pedal is about 3 inches shorter (below) the brake pedal. The clutch pedal is sitting right up against the rubber stop on the front side of the toe board so it is as high as it is going to get. The brake pedal is sitting against the toe board as there is no stop or place to install a stop that would make it lower. Both are properly connected at the pivot and there are new bushings there. Neither of the pedals show any sign of welding so I’m thinking they have not been modified, it just seems strange that they are so different in height. Maybe at some time over the years someone with one short leg installed different pedals.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
There were 2 different brake/clutch pedal setups. One setup had the master cylinder bolting to the frame. I suppose it is possible that you have one pedal from each of the setups?
You just made me walk out in the cold and peek at my coe. The clutch sits 2" lower and deeper-ish then the brake. I think the brake pedal is higher for those times you need both feet to really stop your load...
My 1953 Chevrolet
1947.1 Gallery
jdl Offline
Yeah, what he said. The truck I'm trying to get(54 Chevy 3100) has the brake pedal a little higher than the clutch for (I'm guessing) more leverage.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Riding in the Passing Lane
My 58 was like that. I took the shaft off & took 1 1/4 in. out of it. It looks & feels better.
1972 Chevy c10 Cheyenne Super
Kip -
My 37 has a "stop" under the toe board for the pedal to hit against when it is in the released position. It's a rubber piece that is bolted to the toe board. I think the 41-46 uses the same piece, especially since all of the pedal assemblies are basically the same. Check the Steele Rubber catalog and I think you might find the part there. It could be the same part as the clutch "stop".
Joe smile
Kip, I think Joe has it right. Mine are at the same level. I think you are missing a stop.
George
OK… I didn’t want to do it cause its 5 degrees out there, but I went out to the garage and checked. The toe board had a nice depressed boss area complete with two bolt holes that perfectly fit the rubber bumper pad that I got from Chevs. BUT this is ONLY under the clutch. There is no sigh or indication of any stop in this area for the brake pedal. Maybe the one for the brake is mounted somewhere else, but. I’ve had everything in that area apart and rebuilt and did not see anything that looked like a stop or the remains of a stop for the brake pedal.. Do you guys have rubber bumpers for both the clutch and brake?? Mine is a ¾ ton and the master cylinder is bolted to the frame. All of the linkage appears to be correct and probably original. It does seem a little odd as the brake pedal just sits solid against the front side of the toe board metal to metal and even if the pad for the clutch pedal was removed the clutch pedal would still be a couple of inches lower.???????????
OK, Kip. I'm not saying I'm right, but it just makes sense that there should be a bumper there. What if you come up with a piece of something that you can size to act as a "dummy" bumper for the brake pedal? By doing that, maybe you can get the right thing going on.
On the other hand, with the master cylinder on the frame, there is a long rod, if memory serves me correctly, that it seems can be adjusted to length, as you said. Let's look at that again! As you can tell, I'm kind of stalling here until someone else comes in and tells us both exactly what needs to be done.
Just trying to help!
Joe :crazy:
Kip,
I believe what the manual calls for when you adjust the brake pedal is to have it stop 1/2 inch before it hits the underside of the toeboard. I just added a peice of 1/2 inch rubber with a couple of screws and nuts to hold it in place. Now the pedal has something to bump up against when it is released.
Brian
