2 members (Hotrod Lincoln, 1955 1 Series), 231 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#362855 01/19/2008 6:42 PM
Are the brakes on the '52 Big Bolt Huck or Bendix?
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
Since no one else is chiming in, I'll give it a shot. If the axles are original, which may have been changed one or more times in the last 55 years, they should be Huck style. 52-53 is when the changed happened so you'll have to tear in to them to know for sure.
Good luck, parts are somewhat available for both,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Do they have to be one or the other?
Could they be different all together?
Two wheel cylinders per side in the rear is different....
I don't know the answer either.
Grigg
Grigg #363274 01/20/2008 6:20 PM
I thought 51 was the last year for hucks? Ive got a 52? coe sitting in the yard that has bendix.
The easiest way to tell is to look for the adjustment holes on the front (to the left and right of the Wh Cyl attaching bolts) and the bigger bolts with a spring under them for the rear. Thats how the hucks were adjusted. If all you see is 2 small bolts then you have bendix, no adjustment to the wheel cylinder necessary.
Let us know what you find, Jeff
My 1953 Chevrolet
1947.1 Gallery
Ok, Thanks for the information Jeff.
Cleon
1949 Chevy 6400
