11 members (klhansen, cmayna, Hotrod Lincoln, Peggy M, Wayne67vert, 52Carl, Forty9, walter74, HandyAndy, 2 invisible),
142
Mod | | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 141 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 141 | Hello, As I have been prepping the cab for removal, I have been able to remove a lot of parts that I have been able to clean up. I am looking for a good paint recommendation for items such as:
steering column parking brake assy Radiator support pedal shafts steering box
I hate to ask but is there a rattle can alternative that is worthy?
Thanks, brian | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Eastwood makes some good coatings for natural finish looks $$$. One really good paint I have used is sold at Home Depot(Rust-Oleum)it is an enamel for refinishing appliances. It is about $5.00 a can and if you let it dry overnight after spraying and follow-up with another coat it is very tough and durable. I have used both the black and the white and they are both good. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I go along with Brad. The appliance enamel is some tuff stuff after its dried good. Also remember if you paint anything that will see the sunlight be sure to use emamel as laquer would fade! | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Paint is only as good as the prep work. I like Duplicolor Self-Etching Primer for blasted parts and Rustolium enamels for finish coating detail parts.
Although I like lacquer, it lacks the durability of enamel. | | |
