6 members (Rusted Nut, FAST55, KEVINSKI, Wally / Montana, HandyAndy, 1955 1 Series), 47 guests, and 3 robots.
Topics128,090
Posts1,056,018
Members48,430
#360315 01/13/2008 9:22 PM
the search funtion and i don''t get along yet so i will the posethe question here
remind me, is the rear bumper and the front the same one?
thanks
tom
I don't suffer from insanity, I enjoy every minute of it!
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
NOPE ! ! ! ! they look alike but aren't...Joe
Actually they are the same. When I ordered a rear bumper for my panel the Vendor said it is the same as the front so I ordered two front bumpers and both fit perfect.
38 original
48 panel
59 stepside
46 in the back forty
Looks like we are going to go over this one again. The front and rear bumpers on 1/2 ton Advance-Design panel body trucks are the same bumper.
Tim
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/343959#Post343959
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Ok, I guess I was wrong. I was always told they were different, but then I own a 1ton Panel/Bus...Joe
Leo Offline
Moderator
Moderator
Mine are very different because it has either an incorrect or an optional heavy duty bumper from a big bolt on the rear.
1953 panel,
Does you panel have the rear splash apron (or valance, or stone shield/guard, whatever it is called) that goes between the body and the bumper? If so, is in an evenly-spaced fit all along the bumper?
The 1947-55 panel-body 1-ton bumpers are different from the 1/2 bumpers, is there a chance you have one 1/2 ton bumper and one 1-ton bumper on your panel?
Tim
Over the years Ive switched front and rear bumpers around on my panel and havent seen any difference.
Leo Offline
Moderator
Moderator
No Tim, it does not. Nor does it have the correct bumper brackets. (homemade by PO) I understand the correct rear brackets are not the same as the front brackets or pick up brackets. I have thrown out the rear bumper because a PO torched a hole in it for a wiring harness and welded a trailer hitch to it. He also welded homemade bumper brackets to it. Because I threw it away, I cannot post pix, but on the front cover of my owners manual for 1953 Chevrolet trucks is a bumper identical to mine. It is on a big bolt.
Also,,The panel rear bumper brackets are all by themselves.
Tim
yea!, yea!, yea! grin
with 3 different panels and two having different rear bumpers and the third none at all I was convinced that the front and rear wre the same. I looked at a sub recently that had what i now know is the correct bumpers and it struck me odd at first.The rear bumper brackets are most definitly not the same
thanks as always dance thumbs_up
tom
