| | | Forums66 Topics128,095 Posts1,056,077 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | the search funtion and i don''t get along yet so i will the posethe question here
remind me, is the rear bumper and the front the same one?
thanks tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | NOPE ! ! ! ! they look alike but aren't...Joe | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | Actually they are the same. When I ordered a rear bumper for my panel the Vendor said it is the same as the front so I ordered two front bumpers and both fit perfect.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Ok, I guess I was wrong. I was always told they were different, but then I own a 1ton Panel/Bus...Joe | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Mine are very different because it has either an incorrect or an optional heavy duty bumper from a big bolt on the rear. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1953 panel,
Does you panel have the rear splash apron (or valance, or stone shield/guard, whatever it is called) that goes between the body and the bumper? If so, is in an evenly-spaced fit all along the bumper?
The 1947-55 panel-body 1-ton bumpers are different from the 1/2 bumpers, is there a chance you have one 1/2 ton bumper and one 1-ton bumper on your panel?
Tim | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Over the years Ive switched front and rear bumpers around on my panel and havent seen any difference. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | No Tim, it does not. Nor does it have the correct bumper brackets. (homemade by PO) I understand the correct rear brackets are not the same as the front brackets or pick up brackets. I have thrown out the rear bumper because a PO torched a hole in it for a wiring harness and welded a trailer hitch to it. He also welded homemade bumper brackets to it. Because I threw it away, I cannot post pix, but on the front cover of my owners manual for 1953 Chevrolet trucks is a bumper identical to mine. It is on a big bolt.
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Also,,The panel rear bumper brackets are all by themselves. | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | yea!, yea!, yea!  with 3 different panels and two having different rear bumpers and the third none at all I was convinced that the front and rear wre the same. I looked at a sub recently that had what i now know is the correct bumpers and it struck me odd at first.The rear bumper brackets are most definitly not the same thanks as always  tom
