3 members (baldeagle, Ponchogl, Stovebolt48), 72 guests, and 6 robots.
Topics128,021
Posts1,055,346
Members48,420
#360219 01/13/2008 4:40 PM
Now I know for a fact that this subject has had a lot of discussion before. The search function never never brings back what I am looking for. Very frustrating. I would like to know how a directional system is wired when LEDs are used for indicator lights. Also can someone please clue me on how to use the search function? I cannot make it work no matter what I try. Weeds
Weeds #360223 01/13/2008 4:56 PM
Why is it not working? are you burning them out? Don't believe the package when they state for 12V or 3V or what ever. You need to use a resistor with each one.
http://led.linear1.org/1led.wiz
http://home.cogeco.ca/~rpaisley4/LEDcalc.html
Use one of the above to help figure them out. Also, LED will only work hookup the right way. Try reversing the connectors, if you hear a pop or see a flash, its to late! Led's cannot take a over voltage, more resistor is better then not enough. I have burnt up a bunch of them so I am getting pretty good with them. Joe
Joe H #360253 01/13/2008 6:03 PM
Ex Hall Monitor
Ex Hall Monitor
I believe they wire the same as incandescent bulbs except for the need to put a specialized LED flasher in the circuit because the LEDs don't draw enough current to make the stock flasher work. Another solution is to wire an incandescent bulb into the circuit somewhere hidden so there will be enough draw for the stock flasher to work.
Tiny #360262 01/13/2008 6:23 PM
Weeds, On the search Feature, be sure that the time frame you want to search is correct. It defaults to one week.
As for the LED Tail Lights... Tiny's got it exactly right.
Weeds #360326 01/13/2008 9:47 PM
Weeds - this is the best clue I could come up with... How to use the search engine.
Click on the Search button located between "Active Topics" and FAQ in the tool bar. In the Keyword Search Terms enter +LED +Directional +Wiring (just as displayed here, including the + signs)
In the Date Range "New Than" Box add a zero to the one and change the period to Years. This will search 10 years of posts.
I come up with 28 pages of results if I leave the results per page at 25.
You can narrow your search to just the Electrical Bay or add or ignore certain terms by using the + and - signs in the search box.
Hope this helps.
Don
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
down2sea #360999 01/15/2008 4:48 PM
I don't believe he wants LED tail lights. From what I read, he is looking for LED indicators for the dash. This is a different problem.
Weed, What you need to do is run a wire from the left and right turn circuit up under the dash. You can use very small wire as LEDs don't pull any current. Get the correct amount of resistor in line with the LED and it should work. You may have to install a diode on each side to keep the voltage from back feeding. Think of the diode as a one way check valve, the small stripe around the body is the valve. Voltage comes in from the other side and flows through the diode, if it tries to back feed, it hits the "valve" and stops. A LED will light with such a small amount of voltage, diodes are all most a must have.
http://www.radioshack.com/product/i...odes&kw=diodes&parentPage=search
Joe
