| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Now I know for a fact that this subject has had a lot of discussion before. The search function never never brings back what I am looking for. Very frustrating. I would like to know how a directional system is wired when LEDs are used for indicator lights. Also can someone please clue me on how to use the search function? I cannot make it work no matter what I try. Weeds | | | | | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | Why is it not working? are you burning them out? Don't believe the package when they state for 12V or 3V or what ever. You need to use a resistor with each one. http://led.linear1.org/1led.wizhttp://home.cogeco.ca/~rpaisley4/LEDcalc.html Use one of the above to help figure them out. Also, LED will only work hookup the right way. Try reversing the connectors, if you hear a pop or see a flash, its to late! Led's cannot take a over voltage, more resistor is better then not enough. I have burnt up a bunch of them so I am getting pretty good with them. Joe | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I believe they wire the same as incandescent bulbs except for the need to put a specialized LED flasher in the circuit because the LEDs don't draw enough current to make the stock flasher work. Another solution is to wire an incandescent bulb into the circuit somewhere hidden so there will be enough draw for the stock flasher to work.
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Weeds, On the search Feature, be sure that the time frame you want to search is correct. It defaults to one week.
As for the LED Tail Lights... Tiny's got it exactly right. | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Weeds - this is the best clue I could come up with... How to use the search engine. Click on the Search button located between "Active Topics" and FAQ in the tool bar. In the Keyword Search Terms enter +LED +Directional +Wiring (just as displayed here, including the + signs) In the Date Range "New Than" Box add a zero to the one and change the period to Years. This will search 10 years of posts. I come up with 28 pages of results if I leave the results per page at 25. You can narrow your search to just the Electrical Bay or add or ignore certain terms by using the + and - signs in the search box. Hope this helps. Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | I don't believe he wants LED tail lights. From what I read, he is looking for LED indicators for the dash. This is a different problem. Weed, What you need to do is run a wire from the left and right turn circuit up under the dash. You can use very small wire as LEDs don't pull any current. Get the correct amount of resistor in line with the LED and it should work. You may have to install a diode on each side to keep the voltage from back feeding. Think of the diode as a one way check valve, the small stripe around the body is the valve. Voltage comes in from the other side and flows through the diode, if it tries to back feed, it hits the "valve" and stops. A LED will light with such a small amount of voltage, diodes are all most a must have. http://www.radioshack.com/product/i...odes&kw=diodes&parentPage=search Joe | | |
