| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Any one have the stock frame height of an AD 3100? I can not make out the dimensions on this link because the resolution is too low. Just need bottom of frame to ground. Thanks Scott
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | TTT - Anyone own a tape measure?
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Got 4, one in the garage, one in my F-250, one in the house, and one somewhere else. If you are looking for a loner just let me know.
~Jim
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Your question is a little confusing. The page you linked to does not show a dimension bottom of frame to ground. It shows bottom of front and bottom of rear axle to ground, and floor of bed to ground.
The height of the frame above the ground varies depending on where under the truck you measure it. I don't have a stock 3100 so I can't answer the question even with a tape measure. But you could make it easier for someone to help you by suggesting some exact points you'd like measured.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I also assume you want the measurement with stock tires.
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Got 4, one in the garage, one in my F-250, one in the house, and one somewhere else. If you are looking for a loner just let me know. Nah, just need you to walk out to the garage, open the hood, and get the frame height of your truck from either top of frame or bottom of frame to ground. Now that I know you have few tape measures. Scott
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Your question is a little confusing. The page you linked to does not show a dimension bottom of frame to ground. It shows bottom of front and bottom of rear axle to ground, and floor of bed to ground.
The height of the frame above the ground varies depending on where under the truck you measure it. I don't have a stock 3100 so I can't answer the question even with a tape measure. But you could make it easier for someone to help you by suggesting some exact points you'd like measured. Steve, If I had dimension to the bed, I could then subtract the height of the bed from the frame. And I did ask for exact points in 4 of the other forum pages over the past 2 months. general truck talk Parts for Sale And here besides the Greasy Spoon post which was moved. However most people respond to open ended questions... Scott
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Buddy I would be glad to measure for you however I'm at least 2" lower and running 15" tires. Just let me know if you still need me to measure. I'll use my new tape.
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | That will work, I just need to know the size of tires you are running so I can calculate the difference in rolling radii. While you are at it, can I get you to measure the distance from the hood to top of radiator cap? Need not be exact, just need to know how far I can section the hood, or should I lower and trim the fenders? Thanks in advance. Scott ps. feel free to use either the imperial or metric numbers on your new tape measure
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I'll measure the frame but there is no hood right now. It's a rolling frame until I get the sheetmetal back.
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | OK here's what I've got. First measurement: the frame from the forward edge of the 2nd running board support = 14 15/16". second measurement: from the floor to top of the tires = 25 7/8". Hope this helps. You can add me to your board of directors with a modest salary.
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Jim - thanks, guessing bottom of frame?
What sheet metal are you missing from the truck - just hood, or whole front clip?
Scott.
| | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Scott, Did you try a different year resto pack when you were looking for AD measurements? The scans for 51' are clearer. http://chevy.tocmp.com/chevyresto/51054.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
