1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#352917 12/26/2007 11:37 PM
Any one have the stock frame height of an AD 3100? I can not make out the dimensions on this link because the resolution is too low. Just need bottom of frame to ground.
Scott
TTT - Anyone own a tape measure?
Got 4, one in the garage, one in my F-250, one in the house, and one somewhere else. If you are looking for a loner just let me know.
~Jim
Your question is a little confusing. The page you linked to does not show a dimension bottom of frame to ground. It shows bottom of front and bottom of rear axle to ground, and floor of bed to ground.
The height of the frame above the ground varies depending on where under the truck you measure it. I don't have a stock 3100 so I can't answer the question even with a tape measure. But you could make it easier for someone to help you by suggesting some exact points you'd like measured.
I also assume you want the measurement with stock tires.
~Jim
Nah, just need you to walk out to the garage, open the hood, and get the frame height of your truck from either top of frame or bottom of frame to ground. Now that I know you have few tape measures.
Scott
Steve, If I had dimension to the bed, I could then subtract the height of the bed from the frame. And I did ask for exact points in 4 of the other forum pages over the past 2 months.
general truck talk
Parts for Sale
And here
besides the Greasy Spoon post which was moved.
However most people respond to open ended questions...
Scott
Buddy I would be glad to measure for you however I'm at least 2" lower and running 15" tires. Just let me know if you still need me to measure. I'll use my new tape. grin
~Jim
That will work, I just need to know the size of tires you are running so I can calculate the difference in rolling radii.
While you are at it, can I get you to measure the distance from the hood to top of radiator cap? Need not be exact, just need to know how far I can section the hood, or should I lower and trim the fenders?
Thanks in advance.
Scott
ps. feel free to use either the imperial or metric numbers on your new tape measure grin
I'll measure the frame but there is no hood right now. It's a rolling frame until I get the sheetmetal back.
~Jim
OK here's what I've got. First measurement: the frame from the forward edge of the 2nd running board support = 14 15/16".
second measurement: from the floor to top of the tires = 25 7/8".
Hope this helps. You can add me to your board of directors with a modest salary. thumbs_up
~Jim
Jim - thanks, guessing bottom of frame?
What sheet metal are you missing from the truck - just hood, or whole front clip?
Scott.
Yeah from the bottom of the frame. Check the link below for a close picture of the current build.
http://good-times.webshots.com/photo/2544950350099708909eLgzEP
~Jim
Scott,
Did you try a different year resto pack when you were looking for AD measurements?
The scans for 51' are clearer.
http://chevy.tocmp.com/chevyresto/51054.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
