Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Wally / Montana, farmallb, Peggy M, jasrking, 2-Ton, 1 invisible), 36 guests, and 0 robots.
Topics128,010
Posts1,055,299
Members48,419
#355925 01/03/2008 7:00 PM
I recently purchased a 49 5 window 1/2 ton from a party in Oklahoma The title has the engine code # and not a vin number. Is the original vin # located anywhere on the truck beside the plate on the door? This plate was removed sometime. Is there a vin # on the frame of the truck?
Bennie
49 chevy man #355936 01/03/2008 7:27 PM
First, no such thing as a VIN in 1949. You had engine numbers and manufacturer's ID numbers (on the door plate) and different states used one or the other when titling the trucks.
As to your actual question, the manufacturer's ID number only appeared on the door plate. For the entire AD series (47.2 - 55.1) there was no ID number on the frame.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
Jeff_from_KY #356045 01/04/2008 12:33 AM
Thanks for clearing this up for me. now I know about vin#s and mfg
Bennie
49 chevy man #356064 01/04/2008 1:17 AM
Ex Hall Monitor
Ex Hall Monitor
More accurately there was nothing CALLED a VIN in '49. As you found out most states used the engine number as what is now called the VIN through '55. FYI this isn't the forum for your question. This forum is for computer technical questions. This thread will probably get moved when a moderator finds it.
Tiny #356294 01/04/2008 2:18 PM
Good point, Tiny, I should have been a bit more specific. Thanks.
Jeff Nelson
