| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | I recently purchased a 49 5 window 1/2 ton from a party in Oklahoma The title has the engine code # and not a vin number. Is the original vin # located anywhere on the truck beside the plate on the door? This plate was removed sometime. Is there a vin # on the frame of the truck?
Bennie | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | First, no such thing as a VIN in 1949. You had engine numbers and manufacturer's ID numbers (on the door plate) and different states used one or the other when titling the trucks.
As to your actual question, the manufacturer's ID number only appeared on the door plate. For the entire AD series (47.2 - 55.1) there was no ID number on the frame.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | Thanks for clearing this up for me. now I know about vin#s and mfg
Bennie | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | More accurately there was nothing CALLED a VIN in '49. As you found out most states used the engine number as what is now called the VIN through '55. FYI this isn't the forum for your question. This forum is for computer technical questions. This thread will probably get moved when a moderator finds it.
| | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Good point, Tiny, I should have been a bit more specific. Thanks.
Jeff Nelson
