1 members (klhansen),
107
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,856 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 5 New Guy | | New Guy Joined: Jul 2007 Posts: 5 | Bought a new bed for my 1940 with no holes drilled.Anybody got dimension and location of holes | | | | | Joined: Sep 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 42 | Willis, Try checking out the Mar-K web site. I think they may have a PDF file on drilling holes in the correct locations. Good Luck | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I had my boards in the box and all put together, lined up the box on the frame and drilled the holes from the bottom. I put the bolts in and tightened them up. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I did the same as " Builder ". Set the boards in the correct position on the cross rails, then set your box sides. Mark the holes, disassemble, drill, finish & waterproof the boards including the holes, and reassemble. On my '40, the front panel on the box has a flange that the boards sit on. You can mark the hole locations from underneath. The rear cross sill also has holes but these ones fasten thru the bed strips. | | | | | Joined: Apr 2007 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 92 | I just replaced the bed in my 57. (I know, I have to post the pix) Anyway, I placed the boards in the bed with some bolts and steel strips and aligned everything (time consuming) then marked the bed to frame location from underneath with a sharpie (only two boards) - pulled and drilled the locations - replaced them, bolted everything up - done.
Willis40, I'm guessing your boards are all pre routed? If so, this should work fine for you. Just double-check the measurements for the bed to frame locations on every hole (should be eight - was for me). Then drill them out and use these as your guide for the remaining boards.
Good luck, HC | | | | | Joined: Jul 2007 Posts: 5 New Guy | | New Guy Joined: Jul 2007 Posts: 5 | Thanks for the information on the bed wood location`s.Now can someone help with the front panel and rear cross sill.I need distance between hole`s and bolt size. | | |
