3 members (Hanks custodian, Steelonsteel, 1 invisible), 58 guests, and 0 robots.
Topics128,054
Posts1,055,780
#326152 07/27/2007 11:02 PM
Bought a new bed for my 1940 with no holes drilled.Anybody got dimension and location of holes
#326153 07/31/2007 2:45 AM
Willis, Try checking out the Mar-K web site. I think they may have a PDF file on drilling holes in the correct locations.
Good Luck
#326154 07/31/2007 2:40 PM
I had my boards in the box and all put together, lined up the box on the frame and drilled the holes from the bottom. I put the bolts in and tightened them up.
#326155 07/31/2007 4:28 PM
I did the same as " Builder ". Set the boards in the correct position on the cross rails, then set your box sides. Mark the holes, disassemble, drill, finish & waterproof the boards including the holes, and reassemble. On my '40, the front panel on the box has a flange that the boards sit on. You can mark the hole locations from underneath. The rear cross sill also has holes but these ones fasten thru the bed strips.
1940 Chevy KC 1/2-Ton
#326156 07/31/2007 4:31 PM
I just replaced the bed in my 57. (I know, I have to post the pix)
Anyway, I placed the boards in the bed with some bolts and steel strips and aligned everything (time consuming) then marked the bed to frame location from underneath with a sharpie (only two boards) - pulled and drilled the locations - replaced them, bolted everything up - done.
Willis40, I'm guessing your boards are all pre routed? If so, this should work fine for you. Just double-check the measurements for the bed to frame locations on every hole (should be eight - was for me). Then drill them out and use these as your guide for the remaining boards.
Good luck,
HC
57' Chevy 3100 Stepside
http://www.cardomain.com/ride/2630531
Heavy-Chevy #355675 01/03/2008 3:55 AM
Thanks for the information on the bed wood location`s.Now can someone help with the front panel and rear cross sill.I need distance between hole`s and bolt size.
