3 members (Rick Brown, Jon G, 2-Ton), 170 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#354077 12/30/2007 2:12 AM
hello all in stovebolt world i have a 54 burb im just lining up all the parts im going to need for the build so i was just wondering if the frame under my suburban 1/2 ton is the same as a 1/2 ton pickup.
someone has to know
Leo Offline
Moderator
Moderator
I think they are the same but the rear U shaped cross members may be different, in that there are one or two more in the pickup. Technically, these cross members (if they are different, not sure) are not part of the frame because they bolt on.
Leo #354782 12/31/2007 11:48 PM
Basically the frames are the same. There are different brackets used to mount the body on a panel or Suburban than those used to mount a pickup cab and box. The radiator mount and front cab mounts are the same, the differences start with the mount just back of the seat.
I've taken both apart, and one of the things I wanted to accomplish was a good understanding of those differences.
Leo #354788 12/31/2007 11:59 PM
There are also different bolt-on cross members near the rear of the frame, for the Suburban fuel tank.
There are frame body-mounts that are specific to the panel body (in the rear).
Non of these things would make it difficult to mount a 1954 1/2 ton Pickup bed on a 1954 Suburban chassis.
As stated in another recent thread, the big differences in 1/2 ton chassis are between the 1953 and the 1954/55-1st and the 1955-2nd.
Tim
Cool so i can locate a 54 frame and have it powercoated and built with the exception of the bolt on crossmembers which i can bolt on later after i remove the body from the frame cool is the assembley manual worth the price they are are asking for it on e bay and does it go in to detail on the burban parts?
The assembly manual is definitely worth buying. I don't know what the prices on ebay are, I bought a new reprint from one of the vendors. I'm glad I have that book.
The reprint has limited Suburban specific detail. If you can get an original copy it may have much more information.
Superior Glass Works - www.superiorglassworks.com - makes a reproduction '54/'55 1st pick up chassis that would work for your Suburban.
