2 members (Cletus1950, 1955 1 Series), 68 guests, and 5 robots.
Topics128,172
Posts1,057,105
Members48,463
Apprentice
Apprentice
I have a kit of 100's of bits for torx, allen, phillips, slotted... and don't have one for the screws all over my AD truck, what is the fastener called?
It's a clutchhead screwdriver.
"If you're not first, you're last". Ricky Bobby
1944 Chevy Firetruck
Halloween Decorations
1966 F**d Firetruck
And their D#@* hard to get loose. I bought an assortment of sizes of clutchhead screwdrivers and never could break one loose. I had to resort to drilling and grinding and cussing...
~Jim
Its called a "clutchhead" screw. And chances are, its been in there since the truck was built.
If you can get the proper size driver in there and smack it with a hammer with medium force a couple times,that usually helps to break it loose. A couple shots of penetrating oil usually helps a bunch too.
Good luck...............
littlekings: The clutch head screwdrivers can be bought from about any vendor but you an also find them locally at Home Depot, Lowes, Ace Hardware and some other stores. All of them don't carry them ALL their stores but you can usually find them. Even at sears around here.
Dave Giorgi
Unregistered
Dave Giorgi
Unregistered
Chevy must have caught a sale on those...LOL...they appear to be installed never to be removed again. The drivers just don't cut it well when it comes to removal. Penerating oil and tapping them does help,but boy are they tough. I am replacing mine with the same type head (round) with a stainless steel torx type or the perfer allen. I know its not original but it sure does show off well in contrast as the screws appear crome and , best of all, never rust!!!
I bought a cheap "impact screwdriver" used a common head which would fit snuggly, couple whack with mallet and presto.
Point: Those Impact screwdrivers are really great for turning rusty stuck screws, including cluth head if its a tight fit.
Dave Giorgi
Unregistered
Dave Giorgi
Unregistered
Those impact drivers may be cheap but they sure do work well, loosing or tightening. Love and used mine like mad.
I have had success removing some of the larger ones with a flat head screw driver. I have also slotted the larger ones to take a flat head. The smaller ones I just drilled out.
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
