8 members (Thom75, dt235sd, BC59, Guitplayer, cmayna, 66flea, Bill Hanlon, 1 invisible),
191
Mod | | | Forums66 Topics128,282 Posts1,058,497 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Anyone used a steering column out of a 68 pickup in your AD truck? If so, does it hook up very well? Did you have to cut it? I'm thinking of doing it as a friend has one that he will give me and it is an automatic column which is what I would like to have and it will still be small, sleek and clean looking. Let me know what you have done........and mama always told me to say PLEASE  | | | | | Joined: Oct 2006 Posts: 17 New Guy | | New Guy Joined: Oct 2006 Posts: 17 | Measure the column you intend to use, think about mounting points at both the top at the dash underside and also the base where it goes through the ca. In the inside of the dash the speedo and quad gauge get a little close for bolt clearance. I just got a flaming river 30" that fits well. Check the website to see how the measurements are taken. You need to get all the knuckels/U-joints to the steering box you intend to use. Good luck Wizard 50 | | |
