Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (cmayna, Baby53, dt235sd, Otto Skorzeny, Thom75, BC59), 217 guests, and 4 robots.
Topics128,282
Posts1,058,497
Members48,490
#353404 12/28/2007 3:08 AM
Anyone used a steering column out of a 68 pickup in your AD truck? If so, does it hook up very well? Did you have to cut it? I'm thinking of doing it as a friend has one that he will give me and it is an automatic column which is what I would like to have and it will still be small, sleek and clean looking.
Let me know what you have done........and mama always told me to say PLEASE wink
Measure the column you intend to use, think about mounting points at both the top at the dash underside and also the base where it goes through the ca. In the inside of the dash the speedo and quad gauge get a little close for bolt clearance.
I just got a flaming river 30" that fits well. Check the website to see how the measurements are taken. You need to get all the knuckels/U-joints to the steering box you intend to use.
Good luck
Wizard 50
