1 members (CuzzFuzz),
101
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35312 08/13/2004 3:17 PM | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | I'd dearly love to have a posi or limited-slip differential for my '59 Chevy Apache pickup. I'm told that nobody makes such a unit for old Chevy trucks. Anybody out there ever try to see if anything would fit this removable third-member rear axle? | | |
#35313 08/13/2004 5:21 PM | | Anonymous Unregistered | | Anonymous Unregistered | Never seen one for the HO-33 dropout axle, but the '59 1/2 tons had a posi(or limited slip) option. It was a Dana/Spicer type rear axle like the GMCs were using though. | | |
#35314 08/13/2004 6:16 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Is the truck a 3/4 or 1-ton? If so, Detroit Locker used to make a locking diff for that center section, and I've heard rumors that there might be a few posi units floating around. I just got one of the lockers from eBay. There have also been a few listed in the swap meet - keep your eyes open. | | |
#35315 08/14/2004 2:50 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I've got an Eaton Locker in my '63 that is indestructable. They are really built heavy and has never caused me any problems. Scott | | |
#35316 08/14/2004 7:09 PM | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Well, this is a 1/2 ton truck (3200 series). So, does this mean there's a posi out there somewhere just waiting for me? . . . if I can find it. | | |
#35317 08/14/2004 7:42 PM | | Anonymous Unregistered | | Anonymous Unregistered | It's easy enough to convert to a 12 bolt out of a 67-72. I'm not 100% sure the wheel bolt patterns are the same but I think up through 1970 they are. After 70 they went to the 5 lug wheel. Boo Radley  | | |
#35318 08/15/2004 2:00 AM | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Originally posted by Boo Radley: It's easy enough to convert to a 12 bolt out of a 67-72. I'm not 100% sure the wheel bolt patterns are the same but I think up through 1970 they are. After 70 they went to the 5 lug wheel.
Boo Radley Well, actually, Boo, when I got the truck it had a late '70s 12-bolt rear axle. I got a stock '59 Chevy truck rear axle for it which has a 3.90 gear ratio, which is perfect for me, since the late '70s 5-bolt axle has a 3.07 gear ratio, and my 700 R4 tranny has a 30% overdrive, and a 3.05 1st gear. So, yeah, if push comes to shove and I really have to have a posi, I can always go back to the 12-bolt axle and get a new ring and pinion while I'm at it. But I really like that 3.90 ratio. Does any body need the 235 six and grandma 4-speed floor-shift I took out of it? | | |
#35319 08/15/2004 3:57 AM | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | I used a Dana 44 limited slip with 3.55 gears and 6 lug drums from a '67 GMC in my '59. It worked really well in mud and snow when in the GMC with a 305 v-6, but I'm not sure it would be stout enough if you're building it up for drag racing. Pretty easy swap. I had to weld up spring perches, re-locate bracket for the brake line tee to the left side, and adapt the ends of the park brake cables to work with the backing plates. Used the original '59 lower shock mounts that fasten on the bottom of the u-bolts. Haven't drove it yet though as the rest of of the truck is still under construction.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
#35320 08/16/2004 4:01 AM | Joined: Apr 2002 Posts: 23 Member | | Member Joined: Apr 2002 Posts: 23 | I'm not sure what rear end you have, but the bolt pattern from at least the '37 trucks up to our '94 chevy pickup all have the same bolt pattern. If you get a rear end from a pickup from the late 60's or 70's, make sure it comes out of a 4wd. Otherwise it will have the 5 lug axles.
55 2 dr 210- after college project 56 2 dr 210- after '55 project "D'oh"
#35321 08/16/2004 4:41 AM | Joined: Aug 2001 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 78 | welder + a case of beer = posi-trac
----------------------------------- Rollin' Hard 1946 Chevy 1/2 ton 1959 Phord 1/2 ton 2001 Chevy 1/2 ton
#35322 08/17/2004 9:37 PM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | if you were realy going to take it out to the drag strip alot, it might be worth it to swap back to GM 12 bolt. you could get a brand new 4.10-1 posi unit for arouind $500  but you could count on it to last for wile | | |
