1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#35115 06/28/2003 12:18 AM
Does anyone have any suggestions on what to do
with a stripped spindle (46 chevy panel)
1946 chevy 1/2 ton panel
1937 ford coupe
#35116 06/28/2003 5:21 AM
If tapping it will not restore the threads and you can't find another a good machine shop could weld or build it up and then rethread.
#35117 06/28/2003 2:26 PM
He's right, it *can* be repaired, but it's tricky. There must be some parts trucks out there! Same front axle for many
years, isn't it?
If you can find a machinist willing to do it, one option is to machine off the old threads, then machine a threaded ring
that slides/presses onto the spindle. Then weld that on. But it won't be real cheap, so if it was me I'd keep calling boneyards, etc.
Good Luck!
George
#35118 06/28/2003 2:55 PM
jdhoward: It's like it was explained to me; your driving down the road 55mph hit a pothole front wheel how much do you you trust somebody's weld? I replaced!!! popcorn The Truth is Out There (It's your butt)
#35119 06/28/2003 10:41 PM
I'm a machinist and could fix the spindle, but it would cost you way more than if I just sent you one of the '46 spindles laying on my bench right now. Sometimes replacing a part is way cheaper than repairing it.
To be long remembered as he's cruising in
The Passing Lane
