| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35115 06/28/2003 12:18 AM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Does anyone have any suggestions on what to do with a stripped spindle (46 chevy panel)
1946 chevy 1/2 ton panel 1937 ford coupe | | |
#35116 06/28/2003 5:21 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If tapping it will not restore the threads and you can't find another a good machine shop could weld or build it up and then rethread. | | |
#35117 06/28/2003 2:26 PM | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | He's right, it *can* be repaired, but it's tricky. There must be some parts trucks out there! Same front axle for many years, isn't it?
If you can find a machinist willing to do it, one option is to machine off the old threads, then machine a threaded ring that slides/presses onto the spindle. Then weld that on. But it won't be real cheap, so if it was me I'd keep calling boneyards, etc.
Good Luck! George | | |
#35118 06/28/2003 2:55 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | jdhoward: It's like it was explained to me; your driving down the road 55mph hit a pothole front wheel how much do you you trust somebody's weld? I replaced!!! popcorn The Truth is Out There (It's your butt) | | |
#35119 06/28/2003 10:41 PM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | I'm a machinist and could fix the spindle, but it would cost you way more than if I just sent you one of the '46 spindles laying on my bench right now. Sometimes replacing a part is way cheaper than repairing it. | | |
