3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#350982 12/21/2007 4:13 AM
Apprentice
Apprentice
for those that have changed to a v8 & 700r4, what did you do to activate the torque converter lock up ?
was it difficult ?
did you use an aftermarket kit to make this happen or go to a tranny shop ?
thanks in advance
Cruzer
Cruzer #350995 12/21/2007 4:41 AM
My 700R4 was beefed up by Phoenix and I plan on getting the kit from them when I'm ready for it.
~Jim
Cruzer #350996 12/21/2007 4:46 AM
I purchased a "kick down cable" with the ataching items that bolt to a stud on the carburetor to hold the cable. This is what "kicks it down". To get it to "come out of lock up" when you put your brakes on can be done a couple different ways. I wired a switch into my brake light so that when I put on brakes it would energize the switch and it in turn would kick off the overdrive.
Some do that and even add "security" by hooking up a vacumm line to pull it off...and some just use the vacumn by itself. Hang around here and some more guys will chip in....then make a decision on the way you want to do it.
Achipmunk #351019 12/21/2007 5:49 AM
1 Offline
Mine is controlled by the ECM that controls the fuel injection on my 51 But there are a lot of vendors that make a kit that you can install that looks pretty easy to do... Try TCI 200R4 / 700R4 Torque Converter Lock-Up Kit OR there's one from Speedway Motors then there's Bowtie overdrives and like BIG CHEVY 3600 said Phoenix is another awesome builder take makes a kit too... But either way you go you'll still need to hook up a TV cable like Achipmunk already replied... but it's no big deal if it's adjusted right Bowtie overdrives have some real good tech tips on doing that
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
1Bad51 #351322 12/22/2007 4:11 AM
just make sure that it is adjusted correctly!!!
I bought a solenoid kit for the lockup...
Another quality post.
Real Trucks Rattle
Rusty Rod #352927 12/27/2007 12:01 AM
My buddy uses a vacuum switch and a relay when swapping in a 700 R4, however there are plenty of simple controllers out there on the market. Jegs
Southern Rods and Parts
Summit Racing
HTH
Scott
Riding in the Passing Lane
I get a vacuum switch from a late 80,s van & a 2 prong oil pressure switch used for chokes on late 70,s chevs. Put the oil switch in the 4th gear pressure outlet. Hook the vacuum to ported vacuum on the carb. Wire it all together from a acess. outlet on the fuse panel. Some trans. dont have a taped hole for the pressure outlet. I,m not shure how to do it then but there is a way from inside the trans.
1972 Chevy c10 Cheyenne Super
I got mine from Summit racing.The cable setup.Its been quite a while back, but the unit was priced very reasonable
