5 members (Jon G, Otto Skorzeny, Hanks custodian, dt235sd, 3800GUY), 166 guests, and 1 robot.
Topics128,105
Posts1,056,205
Members48,436
I have a 1929 Chev. truck with a marginal engine. I would like to explore using a later engine without heavy butchery. Would some of you experts, that have been around the block a time or two, please share some advice. I would also consider changing to a later 4 speed trans. but once again, I don't want a bunch of carving to do it.
Regards, Alan
smile Alan
1947 (early) GMC EC-302 Dump Truck
Jimmy
More pix in Photobucket
Welcome to the Bolt. There are several hundred choices in engines you could use without too much fabrication. What do you want this ride to be when finished?
~Jim
Alan I put a 235 in a '33 truck which is basicaly the same as the 29. I had to change the crossmember at the bell housing to one from a 37 truck, other years of the era would probably work.
The 29 engine is longer then the 216 or 235 so I had to modify the front mount to support the engine. I don't know what you intend to do with this truck but if it is not going to be driven a lot I think I would just try to rebuild the present engine.
Good Luck
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
Hello, I intend for this 1929 to be a mostly original with a "6" cylinder engine. I am not set on an absolute original engine or trans, but would like it to be nearly correct. I would like to use a later model 235 if possible with a late 40's 4 speed trans. Is that possible without chopping into the truck much?
Alan
smile Alan
Jimmy
The Chevrolet 4 speeds from 1930 through 1947 are basically the same only minor differences
34 & 35 trucks are the greatest
Hello Cleon,
Thanks for your ideas. I will keep my eye open for a fifties 235 and also a mid 40's 4 speed. If you have nay other ideas on bringing a 1929 vintage truck back to life, let me know. I live in a rural area and would like to use this truck, not just as a show piece but as a working piece of equipment for use on my farm. I know it would be lots of work but I have an, "in the drive-line" aux overdrive that I may look at installing to up the road speed a little. Thanks again for your comments.
Regards, Alan
smile Alan
Jimmy
Since you need a longer engine anyway, I would look for a GMC six cylinder. They are about 1-1/2 inches longer than a 235 and have much better heads and metal quality, and you can get them up to 302 cubic inches.
The mid 40's 4 speed is going to be a crashbox, synchros didn't show up until '48 in the AD trucks.
Paint & Body Shop moderator
