1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | I have a 1929 Chev. truck with a marginal engine. I would like to explore using a later engine without heavy butchery. Would some of you experts, that have been around the block a time or two, please share some advice. I would also consider changing to a later 4 speed trans. but once again, I don't want a bunch of carving to do it. Regards, Alan
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Welcome to the Bolt. There are several hundred choices in engines you could use without too much fabrication. What do you want this ride to be when finished?
~Jim
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Alan I put a 235 in a '33 truck which is basicaly the same as the 29. I had to change the crossmember at the bell housing to one from a 37 truck, other years of the era would probably work. The 29 engine is longer then the 216 or 235 so I had to modify the front mount to support the engine. I don't know what you intend to do with this truck but if it is not going to be driven a lot I think I would just try to rebuild the present engine. Good Luck Cleon | | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | Hello, I intend for this 1929 to be a mostly original with a "6" cylinder engine. I am not set on an absolute original engine or trans, but would like it to be nearly correct. I would like to use a later model 235 if possible with a late 40's 4 speed trans. Is that possible without chopping into the truck much? Alan | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | The Chevrolet 4 speeds from 1930 through 1947 are basically the same only minor differences
34 & 35 trucks are the greatest
| | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | Hello Cleon, Thanks for your ideas. I will keep my eye open for a fifties 235 and also a mid 40's 4 speed. If you have nay other ideas on bringing a 1929 vintage truck back to life, let me know. I live in a rural area and would like to use this truck, not just as a show piece but as a working piece of equipment for use on my farm. I know it would be lots of work but I have an, "in the drive-line" aux overdrive that I may look at installing to up the road speed a little. Thanks again for your comments. Regards, Alan | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Since you need a longer engine anyway, I would look for a GMC six cylinder. They are about 1-1/2 inches longer than a 235 and have much better heads and metal quality, and you can get them up to 302 cubic inches.
The mid 40's 4 speed is going to be a crashbox, synchros didn't show up until '48 in the AD trucks.
