6 members (jmoore, joe apple, Gdads51, 3B, Rusted Nut, 68ironhead), 112 guests, and 3 robots.
Topics128,264
Posts1,058,350
Members48,485
#34998 10/08/2004 11:21 PM
when i got my 54 3100 the speedo worked sorta, did the dance at speeds. my question is i lubercated the head of the speedo and installed a new cable, the odo works but the speedo does not register, any suggestions?
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#34999 10/10/2004 3:48 PM
Although it's not the problem you're describing, my needle will hang up if I screw on the cable to the speedo too tightly. It's like the drive part of the cable is a bit too long and binds up if it's screwed in too far.
#35000 10/10/2004 5:54 PM
Did you compare the old cable with new? Same diameter and length? What was wrong with the old cable? Did you try lubing up the original and you still had problems? My '65 danced a lot when I first got it. Lubed up the cable and all good.
If it's a repro cable, you definitely can't trust that it's the same as original. Seems like if it worked before and all you did was change the cable, either the cable diameter is different and not engaging the gear or the cable's not in the gear.
Wally,
Did the binding occur from the get go or did it get to a certain MPH and hang?
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#35001 10/10/2004 6:26 PM
it has been so lomg since i had the orginal cable i don't rember what happened to it. the strange thing is the odometer works. i didn't notice that til i had the cable installed for a couple of weeks. as is most after market parts made in china or taiwan. they are short over there so maybe so is the inner shaft, ha ha . it is a mystery.
2017 Buick Encore
See more pix
#35002 10/11/2004 8:16 PM
Junior Member
Junior Member
I had a similar problem. The speedo needle would actually go down as speed increased. Replaced head, cable, same thing. The 3spd trans has a spacer to pinch the yoke to the speedo gear riding on the output shaft. In my trans, this was loose, so the speedo gear was not always spinning at the speed of the shaft. Took apart and replaced spacer on shaft. Worked ok. This was also on a 54 3100. I just got it done, so it is still fresh in my memory.
Rapper1
#35003 10/11/2004 10:54 PM
the thing i forgot to mention the trans is from 56 with an open drive shaft. it worked on the old one. i have these senior moments more often!!!!!!!!!!!!!
2017 Buick Encore
See more pix
#35004 10/11/2004 11:27 PM
Does the speedo neele move at all?
You say the odometer works ,,,short cable like you are thinking,,, feed it some viagra grin
#35005 10/15/2004 2:34 PM
somethings are to short but not that.
2017 Buick Encore
See more pix
