10 members (Tronman, Steelonsteel, Peggy M, Rusty Heaps, J Lucas, Wally / Montana, Scott, klhansen, 2 invisible), 65 guests, and 1 robot.
Topics128,206
Posts1,057,433
Members48,471
I am looking at a nice GMC 54 3/4 ton std shift pu. [I had a 53 with a 235 in it] This motor is blue, and has gmc embossed on the valve cover but it has 2 studs for the hold down , looks like a oil filter on the right front of the motor, can anybody tell me what motor it is and do you think its original?
Probably a GMC 228. Look just behind the distributor, there will be a machined flat with numbers/letters stamped into it. the first 3 will be the engine size. 228,270 etc.
248 in 1954
The code plate on the door pillar will have a 24 indicating a 248.
Something like 152 24 PZ 1234
ok thanks it is a 228 , is there any info on this motor. it seems like everything evolves around the 216 and 235. does the 228 have a solid lifter camshaft in it like my old 235 had? thanks Tom
There's plenty of info on GMCs at Old GMC trucks.com
A 228 in a '54? I would expect a 248. A 228 is going to look original in that truck, but I don't think it is original. What does the trucks serial number say?
I will check sn tomorrow, I had it running a little bit ago for the first time since I have owned it and it ran terrible, found the vacuum advance was bad, are those gonna be avaiable at the local parts stores or am I going to have to find someone that has a nos one? thanks Tom
My '54 came to me with no engine but had been changed to a 228 at one time. The title still reads 228xxxxxx. The door plate, of course has 24 on it.
