1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 51 | I am looking at a nice GMC 54 3/4 ton std shift pu. [I had a 53 with a 235 in it] This motor is blue, and has gmc embossed on the valve cover but it has 2 studs for the hold down , looks like a oil filter on the right front of the motor, can anybody tell me what motor it is and do you think its original? | | | | | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | Probably a GMC 228. Look just behind the distributor, there will be a machined flat with numbers/letters stamped into it. the first 3 will be the engine size. 228,270 etc. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The code plate on the door pillar will have a 24 indicating a 248.
Something like 152 24 PZ 1234 | | | | | Joined: May 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 51 | ok thanks it is a 228 , is there any info on this motor. it seems like everything evolves around the 216 and 235. does the 228 have a solid lifter camshaft in it like my old 235 had? thanks Tom | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There's plenty of info on GMCs at Old GMC trucks.com | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | A 228 in a '54? I would expect a 248. A 228 is going to look original in that truck, but I don't think it is original. What does the trucks serial number say?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 51 | I will check sn tomorrow, I had it running a little bit ago for the first time since I have owned it and it ran terrible, found the vacuum advance was bad, are those gonna be avaiable at the local parts stores or am I going to have to find someone that has a nos one? thanks Tom | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My '54 came to me with no engine but had been changed to a 228 at one time. The title still reads 228xxxxxx. The door plate, of course has 24 on it. | | |
