| | | Forums66 Topics128,109 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | im about to shorten a long bed to a short bed on my 66. i feel as tough i might have better luck by doing it with the bedsides off. i know they are just bolted on the end closest to the cab, but what about the tailgate end? | | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Well, from what I saw on a TV show, the tailgate and back stake rack housing is kept intact. I believe they cut out a section about a foot in from the back. It looked pretty straightforward as I remember. They didn't take the bedsides off probably for stability. Don't konw how they did the frame. sovagary
GS
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The show was Trucks! on Spike. They cut the frame under the cab, forward of the rear trailing arm mounts.
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | To remove a bedside, you unbolt the front panel and all the bedwood attached to it and the wheel tub. The rear cross sill has a couple of bolts inside that needs to be removed and then you need to cut the small welds in the corners to get them apart. Good luck, Scott | | | | | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | cool i figured there would be some welds that would have to be cut. i saw that episode on trucks so figured i would give it a try, i found a long bed as straight as can be for 80 bucks so i thought it would be worth a shot......ill keep yall posted thanks again | | |
